Author: Subject: How many relays are you using??
dilley
posted on 2/10/10 at 05:59 PM Reply With Quote
As above, I have 6!!!
dipped beam,
High beam,
Horn,
Ignition,
Reverse switch(through neutral light)
Sarter button (through oil pressure light)
+1...fan relay...=7
Idiot proof.....I hope....does this sound excessive?? oh, by the way, it's a busa.
Tell me what you have???
[Edited on 2/10/10 by dilley]
tomgregory2000
posted on 2/10/10 at 06:03 PM Reply With Quote
i have 7 as well
dipped
high
side
fan
indicators
and 2 for the ecu
steve m
posted on 2/10/10 at 06:07 PM Reply With Quote
None
plantman
posted on 2/10/10 at 06:26 PM Reply With Quote
6 + a spare
NeilP
posted on 2/10/10 at 06:27 PM Reply With Quote
About 6?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
RichardK
posted on 2/10/10 at 06:30 PM Reply With Quote
2
main and horn
oops 3 forgot the flasher relay
[Edited on 2/10/10 by RichardK]
Gallery updated 11/01/2011
steve m
posted on 2/10/10 at 06:53 PM Reply With Quote
ok, two flasher relays, but that is it
speedyxjs
posted on 2/10/10 at 07:56 PM Reply With Quote
7
2 flasher relays
1 main beam
1 dipped beam
1 fuel pump
1 starter motor
1 something else, cant remember
dan__wright
posted on 3/10/10 at 09:48 AM Reply With Quote
6
ign
dip
dim
fuel pump / ecu controlled live
fan
flasher
FREE THE ROADSTER ONE…!!
adithorp
posted on 3/10/10 at 10:14 AM Reply With Quote
Ignition (to the engine loom)
Ignition auxillary (all the stuff thats not switched via relay plus feed for relay triggers)
Dip beam
Main beam
Horn
Wipers
Fan heater
Flasher
Aux2 (12v sockets)
plus the relays in the bike loom
adrian
http://jpsc.org.uk/forum/
Dave Bailey
posted on 3/10/10 at 02:23 PM Reply With Quote
So that anything heavy current does not go through a switch or if the supply needs switching from the ECU:-
1. Headlights main beam
2. Headlights Dip beam
3. Side Lights.. No real need....
4. Fuel Pump
5. ECU
6. Starter Solenoid
7. Indicators (uses a socket)
8. Engine Fan
9. Ignition relay (100 A to Fuse Box)
Dave B
interestedparty
posted on 3/10/10 at 03:21 PM Reply With Quote
Premier universal Sierra based loom used to have 4 (Main beam, dip beam, flasher and delay for the wipers), has 1 more now for the rear fog light so it lights as per IVA requirements.
dilley
posted on 3/10/10 at 04:14 PM Reply With Quote
I have fitted stanbard size relays but I am now thinking of using micro!
