Author: Subject: Garage clearout
flak monkey
posted on 3/10/10 at 09:39 AM Reply With Quote
Garage clearout
Time for another clear out. All prices plus P&P
6mm wheel spacers 95-114mm PCD. SO suit ford and others. £SOLD
Image deleted by owner
Sierra Haynes Manual - well used but all intact £5
New 4 wire narrow band Lamda sensor. Its a denso one with the part number 12559850 £20
Lamda sensor
Lamda sensor
90mm rotrex pulley. Did about 100miles with it fitted so basically as new! £40
90mm rotrex pulley
90mm rotrex pulley
Phormula KS3 to KAP interface kit £10
Phormula cable
Phormula cable
Large official LCB sticker. New and still in the tube. £5
Megasquirt 1 V3 main chip. Removed from my working MS1 ECU when I upgraded to MS2. No problems with it when removed and its been stored in an anti-static bag. £SOLD
2 off Carbon Fibre NACA ducts. Bought with the intention of fitting to the GTS but never bothered as temps stayed well under control. They are Carbon Mods ones. £SOLD each
M12x1.25 wheel nuts. Not ford fit. Set of 10. £10
Ford zetec/duratec clutch plate. Has the smaller splines so wont fit a type 9 but will fit all the FWD geaboxes. £10
Clutch plate
Clutch plate
1.5" 45 deg stainless bends. 4 off. £20
Various sizes of Duratec cam followers. All virtually zero miles so no wear.
182 x1
142 x3
262 x3
302 x2
282 x2
New ones are £10 each from Cosworth. So £5 each.
Think thats it for now....
[Edited on 3/10/10 by flak monkey]
Sera
http://www.motosera.com
matt_gsxr
posted on 3/10/10 at 09:46 AM Reply With Quote
I'll take the spacers.
Matt
franky
posted on 3/10/10 at 10:00 AM Reply With Quote
u2u sent about the duct.
Bass1st
posted on 3/10/10 at 10:07 AM Reply With Quote
Also U2U sent about the duct
MakeEverything
posted on 3/10/10 at 11:44 AM Reply With Quote
U2U sent re: MS1 V3 chip.
Kindest Regards,
Richard.
matt_gsxr
posted on 9/10/10 at 09:24 AM Reply With Quote
thanks David,
the bits arrived this morning
Matt
MakeEverything
posted on 9/10/10 at 07:56 PM Reply With Quote
MS Chip arrived today. Thanks David.
Kindest Regards,
Richard.
goaty
posted on 10/10/10 at 12:01 PM Reply With Quote
hey dave, been a while....lol.
I think i currently have a 110mm pulley on mine, cant remember. ITs the largest they have...is that correct?
if so i will take your please.
cheers agian
joe
