David_17
posted on 5/10/10 at 07:17 PM |
Expansion tank
Can someone confirm if i block off these 2 spare outlets, i've got it piped up correctly?
I've got the very top one going to the bleed outlet on the thermostat.
Cheers.
Dave
dan__wright
posted on 5/10/10 at 07:23 PM |
No, the top one is overflow. Blank one and move the top pipe to the other
FREE THE ROADSTER ONE…!!
dan__wright
posted on 5/10/10 at 07:24 PM |
dan__wright
posted on 5/10/10 at 07:25 PM |
David_17
Where does the top one (overflow?) go to??
Thanks for the quick reply!
dan__wright
posted on 5/10/10 at 07:27 PM |
Leave the pipe off or use a bit of pipe with the other end open near the ground
David_17
posted on 5/10/10 at 07:28 PM |
Ok. Cheers
dan__wright
posted on 5/10/10 at 07:36 PM |
No problem
Ps its a header tank not an expansion tank as they work In different ways
David_17
posted on 5/10/10 at 07:38 PM |
Learn something new every day
boggle
posted on 6/10/10 at 09:20 AM |
quick question...will your nose cone cover the rad cap? ie can you remove the cap without removing the nose cone?
u2u me for details
David_17
posted on 6/10/10 at 09:28 AM |
Yep, i've got plenty of clearance, i'll need a long funnel to fill it though.
dan__wright
posted on 6/10/10 at 09:35 AM |
looking the pics again ( i was on my phoen last night) im not keen on the top rad pipe, would be worried about air getting trapped there.
David_17
posted on 6/10/10 at 09:40 AM |
That was my thoughts too, so i've put a vent in it. I can't have the tank any higher, and the pipe won't really go any lower, unless
i take it really low, but it got dark. May have a rethink today.
Thanks for the tips
