Author: Subject: cutting fibreglass
steve8274
posted on 13/10/10 at 07:15 PM Reply With Quote
cutting fibreglass
hi all
i need to make some amendments to my nose cone.
whats the best, easiest and neatest way of cutting it
thanks
steve
posted on 13/10/10 at 07:17 PM Reply With Quote
I've always used an angle-grinder with a thin cutting disc... wear a mask - the dust will cover you and everything in sight!
It's Evolution Baby!
tegwin
posted on 13/10/10 at 07:19 PM Reply With Quote
I found a thin diamond tile disk made the least mess and neatest cuts... it seems to melt its way through rather than tearing
www.verticalhorizonsmedia.tv
austin man
posted on 13/10/10 at 07:30 PM Reply With Quote
dremmel type tool with either the cutting disk or a router / drill bit as said wear a mask
Coopz
posted on 13/10/10 at 07:31 PM Reply With Quote
I do it by hand, put some masking tape on the area your cutting, mark it out then use a junior hacksaw and a file or two too finish it off!
RK
posted on 13/10/10 at 07:33 PM Reply With Quote
angle grinder cutting disc.
posted on 13/10/10 at 07:36 PM Reply With Quote
+1
interestedparty
posted on 13/10/10 at 07:41 PM Reply With Quote
Unless I missed it you didn't say straight or curve?
For curves I like a coping saw from the gel coat side, with a good sharp blade.
dhutch
posted on 13/10/10 at 08:24 PM Reply With Quote
I did my boot box with a jigsaw and a fine hss blade. Worked ok, do it outside if you can, dust goes everywhere and makes you itch.
Dangle_kt
posted on 13/10/10 at 08:38 PM Reply With Quote
+1
Burned out mine doing my nose cone.
Chippy
posted on 13/10/10 at 10:28 PM Reply With Quote
I always use a jigsaw fitted with an abrasive blade, (not a saw blade). Tape well with masking tape so the saw dosen't mark whatever your cutting, and the jobs a good un! HTH Ray
RazMan
posted on 13/10/10 at 10:31 PM Reply With Quote
1mm cutting disc is by far the quickest, easiest and most accurate (once you get the hang of it) I used to use a carbide jigsaw but it was too violent and the cutting wheel just glides through - you can even do gentle curves if you just use the edge of the wheel.
Raz
alistairolsen
posted on 14/10/10 at 07:00 AM Reply With Quote
diamond disk for straight cuts, hacksaw or coping saw with masking tape for curves, air saw with a hacksaw blade or fine jigsaw works well too.
My Build Thread
robertst
posted on 14/10/10 at 08:21 AM Reply With Quote
that's what i used and it went perfect!
i'd use the dremel only for detailing.
Tom
wescottishmatt
posted on 14/10/10 at 10:54 AM Reply With Quote
another Dremmel fan here. Did all mine with a dremmel and finished anything with a file.
Mask and safety glasses essential. The little dremmel cutting discs tend to shatter is abused to much.
speedyxjs
posted on 14/10/10 at 12:56 PM Reply With Quote
I used an angry grinder with a cutting disk. Went through it like a knife to butter
Nick Skidmore
posted on 14/10/10 at 12:58 PM Reply With Quote
rotozip
Badger_McLetcher
posted on 14/10/10 at 01:25 PM Reply With Quote
Angry grinder, with fine disk.
Basically anything with small teeth that won't cause it to delam.
Also a mask is NOT optional, you don't really want to be breathing this stuff. Or getting it on your skin if you can avoid it, it itches like buggery.
If disfunction is a function, then I must be some kind of genius.
twybrow
posted on 14/10/10 at 02:55 PM Reply With Quote
Do a search! This has been covered so many times!
interestedparty
posted on 14/10/10 at 04:59 PM Reply With Quote
Alternatively, use a coping saw, it's a bit slow but dust is minimal and accuracy is very high. A lot of necessary cuts on nosecones etc will be curved, too, so angle grinder not much good.
