Author: Subject: 2.0 pinto head
Stuart_B
posted on 17/10/10 at 07:50 PM Reply With Quote
2.0 pinto head
hi all, anybody got a 2.0 pinto head, sitting around they with to part with?
please get in touch.
handyandy
posted on 17/10/10 at 08:11 PM Reply With Quote
I,ve got a Pinto head, but not sure if its the 2.0ltr head ( how can i tell the difference?)
If its suitable , its available.
cheers
andy
Stuart_B
posted on 17/10/10 at 08:18 PM Reply With Quote
hi, i am not sure how you tell the difference.
does it look like this
stuart
handyandy
posted on 17/10/10 at 08:39 PM Reply With Quote
The head isn,t at home , so i,ll check it first thing in the morning, if you U2U me a phone number I,ll get in touch with info of the head.
cheers
andy
snapper
posted on 18/10/10 at 04:59 AM Reply With Quote
Measure the valves 42 in 36 ex i belive for the 2.0L
If you can measure fluid in upturned chamber, should be 48cc for a 2.0L
I eat to survive
I drink to forget
handyandy
posted on 18/10/10 at 06:28 AM Reply With Quote
Thanks Snapper, thats great info
Stuart........I,ll check it later this morning but won,t be online till around tea time so will post up the info when i get home.
cheers
andy
gavin174
posted on 18/10/10 at 10:00 AM Reply With Quote
what you looking for stuart.
standard or modded..
I have a very lively 2.0 head...
has big valves and has had port work done on it...
from memory its a Burtons stage 3 head, but would need to measure the valve's to confirm
no cam fitted.
been gathering dust for a few years now.
[Edited on 18/10/10 by gavin174]
Jomibo
posted on 18/10/10 at 11:31 AM Reply With Quote
I have a ported 2 litre pinto head, big valve, with kent cam and vernier pulley, complete ready to go. Just came on to advertise it, but will wait on your reply first.
[Edited on 18/10/10 by Jomibo]
handyandy
posted on 18/10/10 at 06:55 PM Reply With Quote
sorry for late info.
I,ve got the info from the head,
I,ll type it up in another post.
cheers
andy
Stuart_B
posted on 18/10/10 at 06:59 PM Reply With Quote
cheers andy,
u2u everybody as well
stu
handyandy
posted on 18/10/10 at 07:00 PM Reply With Quote
The inlet valves are 32mm
exhaust valves 42mm
on the corner of the head is the marking "2C"
inside the head(under the cam is the following
84 shm6090d8
92
dn
clock type face 17891c2345 with flat head type screw head pointing between the 7&2
on the camshaft...76mm=6250AA
the cam has the Ford insignia on it.
also got a spare Piper camshaft, never used.
hope the info helps.
cheers
andy
handyandy
posted on 18/10/10 at 07:03 PM Reply With Quote
Originally posted by Stuart_B
cheers andy,
stu
I,ve just this minute got in, wanted to get the info to you as quick as poss........
cheers
andy
Stuart_B
posted on 18/10/10 at 07:17 PM Reply With Quote
cheers andy.
does anybody know what if this is a 2.0 pinto head, as i can not find the value sizes to match up with them?
cheers
stuart
gavin174
posted on 18/10/10 at 07:29 PM Reply With Quote
I think its in the Burtons catalogue.
If not should be in haynes manual.
Sorry can't be more help working in cold/dark scotland tonight.
Stuart_B
posted on 18/10/10 at 07:32 PM Reply With Quote
been looking, on line says "Standard valves are 42mm inlet and 36mm exhaust"
