BigDawgV8
posted on 18/10/10 at 08:43 PM |
Difference in Size - Type 9 and MT75
Hi All,
May be a stupid question but.....
How much of a difference in size is there between the Ford Type 9 and MT75?
In particular are the bell-housings a similar size and shape.
Basically will a MT75 fit where a Type 9 used to be?
Thanks again for the advice!
meany
posted on 18/10/10 at 09:39 PM |
hope these help.
http://www.locostbuilders.co.uk/upload/4Type9.jpg
http://www.locostbuilders.co.uk/upload/Sierra-MT75.jpg
RAYLEE29
posted on 19/10/10 at 02:53 PM |
kinda depends on the amount of space you had around the g/box in the first place. the mt75 is bigger all round
also if you have room in the tunnel for the pia donut youll also need a new prop and also the mt75 is heavier than the t9
Ray![](/images//smilies/smile.gif)
paul@firstmotion
posted on 22/10/10 at 08:42 AM |
Hi
Approximate dimensions for MT75 are as follows 650 mm from bell housing to prop flange
290mm deep on the main case with a width of 200 mm diameter of rear prop flange is roughly 180 mm bell housing pattern on 2.0 is the same as 1.6/2.0
pinto pattern and should be roughly the same diameter.
Hope this is of help if you need some more info email me paul@firstmotion.co.uk
