Author: Subject: Fury front brakes
mrwibble
posted on 20/10/10 at 01:28 PM Reply With Quote
Fury front brakes
apologys if this has been done to death, but i want a quick consensus on after market calipers, discs and pads for a road going 2lt zetec fury, with sierra uprights and independent rear, running drums. I'm thinking 2pot front will be fine, something from wilwood perhaps. I've a .625 front girling cylinder and .75 rear as reccomended by the factory. and will be running a bias bar (fixed for iva purposes.
grateful for any advice, which means i dont have to ring bgh geartech and have chris try and sell me some calipers.
mrwibble
[Edited on 20/10/10 by mrwibble]
MK9R
posted on 20/10/10 at 01:57 PM Reply With Quote
I have hi-specs, they haven't got much feel but work fine. Alot of the other RGB'ers don't rate them and tend to use the Willwoods, butt can't tell you which ones
Oh when do you want this bonnet?
[Edited on 20/10/10 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
adithorp
posted on 20/10/10 at 02:30 PM Reply With Quote
I've got the same pedal set-up as you and I'm running Wilwood Powerlites (from RallyDesign) with Mintex 1144 pads and solid discs.
Very happy with them. Never had fade on track or even going full chat down Alpine passes.
adrian
http://jpsc.org.uk/forum/
v8kid
posted on 20/10/10 at 04:01 PM Reply With Quote
Hi spec, 280 disc on a 13" wheel and ferodo pads here. Seems OK to me.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
matt_gsxr
posted on 20/10/10 at 05:50 PM Reply With Quote
Outlaw aka Bremsport aka loads of other things.
Similar to the Wilwoods but came with a pile of bits when I bought my chassis.
Wilwoods are probably the most sensible option.
stevebubs
posted on 20/10/10 at 07:10 PM Reply With Quote
Standard brakes with Hawk Black pads for me...
mrwibble
posted on 21/10/10 at 08:52 AM Reply With Quote
thanks guys, what disc diameter fits on 13" wheels?
just had a look at the rally design website, eek, how do work out the bore size i need!
