Author: Subject: Side lights - permanent live?
smart51
posted on 24/10/10 at 01:21 PM Reply With Quote
Do side lights have to be powered from a permanent live and dipped / main beam powered from the ignition?
The switch I bought from CBS only has 3 pins so all the lights have to be powered from the same source. I'm a bit annoyed because the hazard switch I bought from them also has 1 fewer pin than is actually needed.
snapper
posted on 24/10/10 at 01:26 PM Reply With Quote
Yes run power through fuse box permanent live to switch
I eat to survive
I drink to forget
Guinness
posted on 24/10/10 at 02:42 PM Reply With Quote
Could you wire the hazards and the side lights from a permanent live and run the "out" side of the mains through a relay that only works when the ignition is on?
RazMan
posted on 24/10/10 at 04:06 PM Reply With Quote
The CBS switch is the simplest way of wiring the lights. Personally I would have the headlights powered from a switched live so that you can't make the easy mistake of leaving the headlights on when parked - one advantage of using the Sierra switchgear.
Raz
big_wasa
posted on 24/10/10 at 04:28 PM Reply With Quote
use the switch to power relays.
the switch and side's relay is perm live and the others of a switched live.
job done
