Thrashed
posted on 24/10/10 at 08:14 PM |
Zx6r carbs
Hi all. After some help.
Final fitting of the fuel pipes to the carbs. From the tank to mechanical fuel pump is is 8mm. Then from pump to carb is the problem. The pump
outlet is 8mm as expected but the carb is about 6.5 to 7mm.
Has anyone else had this problem? Is it just a case of doing up the jubilee clip tight?
Any experiences, views, thoughts and pictures all welcome
RichardK
posted on 24/10/10 at 08:17 PM |
Wonder if you can get a fuel filter with diffent sized ends that could act as a reducer?? Just a thought.
Rich
Gallery updated 11/01/2011
jacko
posted on 24/10/10 at 08:19 PM |
HI And welcome
What engine you using ?
don't use the pump you have and fit a electric bike pump you will have all sorts of problems with what you have
do a search on here
Jacko
Thrashed
posted on 24/10/10 at 08:34 PM |
Hi jacko
Running a 2.0 pinto. Standard cam.
What problems are likely to appear?
whitestu
posted on 24/10/10 at 08:39 PM |
If using the Pinto pump the fuel pressure will be too high. Get an electric bike fuel pump - ideally from a ZX6, but most bike carb pumps work at
similar pressures so will work fine.
BTW I have ZX6 carbs on my Zetec and they are great.
Stu
jacko
posted on 24/10/10 at 08:48 PM |
Stu
Stu is spot on dont bother with a regulator just fit a bike pump ie zx6r / zx9r
they deliver the fuel at the right pressure for the carbs
I have a filter before the pump and after the pump just before carbs
Thrashed
posted on 24/10/10 at 08:53 PM |
Thanks guys. Some good advise.
Jacko, why 2 filters?
Where in the system do you fit the pump? Near the tank at the back or in the front nearer the carbs?
jacko
posted on 24/10/10 at 09:03 PM |
Pump at rear the pumps push better then pull
I have seen them at the front before so may be ok
2 Filters first to stop crap out the tank no2 to stop what the first missed
i just use them cheep inline filters and change them every year
snapper
posted on 25/10/10 at 04:27 AM |
To attach pipes of different sizes use CBS inline pipe reducers, they do a range of different sizes.
I eat to survive
I drink to forget
Thrashed
posted on 25/10/10 at 05:32 PM |
Thanks for the advise guys. Looks like a swap to a bike pump, which isn't too bad as cost is about the same as a regulator for mechanical pump.
If anyone has any pics or diagrams that would be great.
