Author: Subject: Dry sump pump
Dan.
posted on 27/10/10 at 11:27 PM Reply With Quote
Dry sump pump
NTDWM Bit gutted as I just sourced mine.... anyway had my search left on ebay and this has come up with no reserve!
3 Stage Dry Sump Pump on eBay (end time 03-Nov-10 19:15:25 GMT)
[Edited on 27/10/10 by Dan.]
posted on 28/10/10 at 09:12 AM Reply With Quote
Ooooh blimey! I suspect it might go up in price a bit but it's so what I want!!!
posted on 28/10/10 at 09:36 AM Reply With Quote
I like the fact that it's on the bedside cabinet
v8kid
posted on 28/10/10 at 11:30 AM Reply With Quote
Look at the scoring of the internal lobes. My guess is the engine has blown and the pump has been attempting to pump a mixture of oil and metal.
Technical term for this is Gubbed
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Slutters
posted on 28/10/10 at 04:06 PM Reply With Quote
Hi guys the pump is mine, and i am not sure what you mean by scoring? I have seen dry sump pumps after a blow up and trust me this is not one!
Theres no teeth missing or cracked/damaged so not sure why you say that??
v8kid
posted on 28/10/10 at 04:51 PM Reply With Quote
Hi. There was another view on the listing which looked down through the ports and scoring could be seen on the lobes. This is usually caused by a engine failure of some sort.
In my case it was a specialist front casing becoming porus, the roller tappets seized, the cams spalded, with all the debris being pumped through the engine.
Pump lobes looked just like that view I saw on ebay afterwards.
The casing supplier was a gentleman and replaced all the damaged components (cams, followers, pump, bearings and tappets aside from the casing!!) at his cost although I had the hastle of hauling the engine out and rebuilding it.
Slutters
posted on 28/10/10 at 07:54 PM Reply With Quote
Ouch! That is not a nice story!
There is some small marks but they don't appear to be more than just wear marks, it turns freely enough?
