Author: Subject: Any carpenters or joiners - door frame repair advice
posted on 2/11/10 at 02:48 PM Reply With Quote
Busy re-painting the front door and frame etc and realise it's a bit more rotten than I thought. As per the pics below I've dug out all the wet rot back to sound timber and have applied wet rot treatment liberally.
I started trying to build up filler, but it's just to big an area to fill and shape any sense. It's also nigh on impossible to fill upwards into the gap on the inside of the frame.
What's best to do - try and cut back a bit more square and patch some new timber in then fill and paint?
Surrey Dave
posted on 2/11/10 at 02:52 PM Reply With Quote
Yep!
I would cut through above the rot and replace the timber, bit of paint and filler would be ok for years.
mookaloid
posted on 2/11/10 at 02:59 PM Reply With Quote
Yep let some good treated timber in and it will be fine.
corrado vr6
posted on 2/11/10 at 03:02 PM Reply With Quote
If it were me id cut it on an angle like this
And then glue and screw a new piece of timber in jobs a goodun!
http://r1indy7.wordpress.com/
posted on 2/11/10 at 03:06 PM Reply With Quote
Ah ha! I forgot you're a chippy type.
That was what I had in mind, but not having tackled anything like this before thought I'd seek advise.
flak monkey
posted on 2/11/10 at 03:16 PM Reply With Quote
Cut at an angle, but the other way to above ^^
Liberally coat the join with good wood glue (such as a polyurethane based one) and screw through both at an angle. Fill and paint.
Sorted for another 50 years
Sera
https://www.facebook.com/sera.jay666
corrado vr6
posted on 2/11/10 at 03:45 PM Reply With Quote
^^^^ Yep he's right^^^^
will stop the ingress of water in the joint
carpmart
posted on 2/11/10 at 04:14 PM Reply With Quote
I'm no chippy but the above logic re the cut angle is sound!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
posted on 2/11/10 at 04:29 PM Reply With Quote
Thank you chaps - I'll be making a start tonight!
posted on 2/12/10 at 10:01 PM Reply With Quote
Following the advice I started the repair. Due to the awkward profile of the aluminium sill, the multi piece construction of the wooden frame, limited skill and tools I decided to cut it square and replace in 3 parts. First part fitted as below, 2nd and 3rd part fitted with pics to follow when it it's not buried in snow
repair 1
repair 1
repair 2
repair 2
repair 3
repair 3
Fully glued and screwed to the sound timber and sill, filled and ready to sand for painting. Quite satisfying really, although if I had the cash available I would pay someone to rip it out and fit a full UPVC frame and door and have done with any further maintainance
posted on 12/10/17 at 01:03 PM Reply With Quote
Don't know why, but I found this old thread.
Whole door and frame now replaced with a composite door and UPVC frame. Easier to open and close, far less draughty and no rainwater ingress either. Job done in a day and good results - happy chappy
