Author: Subject: Ford Engineers / Machanics
grusks2
posted on 7/11/10 at 07:56 PM Reply With Quote
Is there ford mechanic/engineer out there/on here?
Whilst giving my car (mondeo 2.2 tdci st 56 reg ) a service, I went to change my filter, and it was tight as a nun's
Then this happened
[img][/img]
The plastic filter cap has a plastic nut, which cracked and leaked out oil. Managed to get the old one off ( had to use a hammer and chisel as the plastic nut 35mm just fell apart )
Think fords must have used an air gun to do it up.
Can these be bought on there own or is it a new oil pump..
And to top it off, when I drain the oil from the sump into my nice new bucket, it had a hole so there is oil over the drive, at least I cant move the car so the wife cant see the massive oil slick
[Edited on 7/11/10 by grusks2]
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
posted on 7/11/10 at 07:58 PM Reply With Quote
Whoops, they are only supposed to be tightened to about 20NM or so
drury318
posted on 7/11/10 at 08:04 PM Reply With Quote
I work for one of the major breakdown companies and I have known these be stolen in the night, presumably by people in a similar position to you! Yes they are available on their own but you may have to order it I don`t think they are a stock item.
steve m
posted on 7/11/10 at 08:34 PM Reply With Quote
Is this the part ??
Also very worryingly, i was going to do an ooil change on my 2008 2.0 TDCI tomorrow !!
BRAND NEW OIL FILTER CAP BOWL FORD MONDEO 2000-2007 on eBay (end time 26-Nov-10 20:18:11 GMT)
Or
OIL FILTER CAP BOWL MONDEO DURATORQ 2000-2007 DURATORQ on eBay (end time 02-Dec-10 08:30:56 GMT)
and there in Essex !!
[Edited on 7/11/10 by steve m]
speedyxjs
posted on 8/11/10 at 07:12 AM Reply With Quote
Gunk do some great driveway cleaner you can get from halfrauds. Wroked very well when this happened:
Dad never knew
steve m
posted on 8/11/10 at 08:08 AM Reply With Quote
I now always use a big 24" x 24" deep sided tray, under the car, with the oil catch tank sitting inside, usually bought from garden centres
As i have had similar problems on an oil change !!
grusks2
posted on 8/11/10 at 08:28 PM Reply With Quote
Originally posted by steve m
Is this the part ??
Or
Yeah thats the one, £15 from fords, there not kept in stock but i got it delivered the same day from fords if you order one before 10am.
Looks like im using the mondeo for work tomorrow and not the wifes corsa or the MAC#1
