New Topic New Reply
Author: Subject: Brake Pipe Bulk Head/ Tabs/ Brackets suitable for MR IVA man
StuartBJ
posted on 10/11/10 at 10:02 AM Reply With Quote
Morning Guys,
I`m after a little advise this morning (as usual).
I`ve run my brake pipes on the car but my chassis doesn`t come with brake line bulkheads/tabs/brackets as standard and therefore I have to make some up and fit them for the flexi`s (which I would like to order this weekend from Russ).
As my chassis is already powder coated welding isn`t really an option so my engineering head is telling me a 2 inch peice of angle bar bolted/riveted to the chassis (in a suitable location).
I really want to make sure these are SAFE and will make me IVA man happy.
Sound OK?
All the best
Stuart
adithorp
posted on 10/11/10 at 10:29 AM Reply With Quote
Bolted on should be OK provided the bolt hole isn't significantly weakening the chassis. I'd think you'd be OK with bigish rivets but not 100%.
http://jpsc.org.uk/forum/
Bluemoon
posted on 10/11/10 at 10:36 AM Reply With Quote
6mm rivenuts (probably over kill) and a L bracket will do.
You can use hard line if you like using the proper break line cips, using the L braket as a place to covert from hard-line to flexy pipe.
Dan
russbost
posted on 10/11/10 at 10:41 AM Reply With Quote
Stuart 2mm ali angle held with a pair of normal 1/8 rivets should be fine. Unless there is something drastically wrong with the brake line installation there should be virtually no load on these mountings anyway & if the chassis is sufficently marginal that you couldn't safely drill a few 1/8 holes in it here & there then I think you have more major probs on your hands!!!
StuartBJ
posted on 10/11/10 at 11:52 AM Reply With Quote
Great, thats put my mind at ease.... I`ll dust off the rivet gun and make up the brackets myself
Thanks Guys
Miks15
posted on 10/11/10 at 05:33 PM Reply With Quote
ive done mine exactly as russ as said, 2mm ali angle rivetted to the chassis,
Works fine
New Topic New Reply
