Author: Subject: Hayabusa atmospheric air pressure sensor
Davegtst
posted on 10/11/10 at 03:23 PM Reply With Quote
Quick question. Does the tube on the atmospheric air pressure sensor need to be conected to anything? Mine was loose in a box and the manual doesn't really come up with much.
yorkshire-engines
posted on 10/11/10 at 04:54 PM Reply With Quote
Hi the atmos sensor has 2 bolt fixings this isnt connected the tube just sits there
the map sensor on airbox has 1 bolt and needs to be connected to the throttle bodies thin tubes
cheers Malc
Davegtst
posted on 10/11/10 at 05:00 PM Reply With Quote
Cheers Malc, though so just wanted to check.
Breaker
posted on 10/11/10 at 07:09 PM Reply With Quote
Just make sure the tube is facing downwards to avoid dirt or condensation.
