Author: Subject: FS: S1 Elise (K-Series) Cams, Exhaust, Cat & De-Cat
Bitsablade
posted on 14/11/10 at 10:46 PM Reply With Quote
As per subject - I have the following items for sale that were taken from an S1 Elise...
Pair (inlet & exhaust) of standard 1.8 (118Bhp) K-Series cams - £60+p&p
Specs
Casting: LGC 10201
Inlet opens: 12deg BTDC
Inlet closes: 52deg ABDC
Exhaust opens: 52deg BBDC
Exhaust closes: 12deg ATDC
Duration: 244deg
Inlet valve lift: 8.8mm
Exhaust valve lift: 8.8mm
Original S1 Elise exhaust silencer - £50+p&p (collection pref due to size and weight)
Original S1 Elise catalytic converter - £25+p&p
S1 Elise Mild-steel de-cat pipe - £5+p&p
[Edited on 14/11/10 by Bitsablade]
Front Row Joe
posted on 15/11/10 at 07:28 AM Reply With Quote
Can you let me know the dimemsions of the cat please? I may be interested in that and the pipe. Thanks. Joe.
Bitsablade
posted on 15/11/10 at 10:38 PM Reply With Quote
No problem Joe - the dimensions of the cat are as follows:
Length: 36.5cm
Width: 17cm
Depth: 9cm
For info, the de-cat pipe has a 2" bore.
Photo below shows bolt spacing of both the cat and the de-cat pipe:
Mark
Bitsablade
posted on 1/2/11 at 11:05 PM Reply With Quote
All items still for sale, but now at the following prices:
Cams - £40 + p&p
Silencer - £25 + p&p (collection preferred due to size and weight)
Cat - £20 + p&p
De-cat - £5 + p&p
