Author: Subject: BEC springs
marcjagman
posted on 19/11/10 at 04:40 PM Reply With Quote
BEC springs
As per title really, after some front springs for a BEC. Don't want too soft, who sells them? Have looked for some but obviously not looking in the right places, what poundage should I be looking for?
carnut
posted on 19/11/10 at 04:44 PM Reply With Quote
I have always got mine from www.dfaulknersprings.com. They are really helpful and do just about every rate and size you would ever need.
If its 1.9" springs your looking for I have 2x 175lb and 2 x 250lb (i'd have to check) from my Protec Shocks for sale.
marcjagman
posted on 19/11/10 at 04:46 PM Reply With Quote
Just measured them, 2 1/4 inch I.D.
[Edited on 19/11/10 by marcjagman]
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 19/11/10 at 04:50 PM Reply With Quote
175lb would be too weak i would think on the front of a CEC or BEC
carnut
posted on 19/11/10 at 04:54 PM Reply With Quote
Appologies my memory is rubbish. They are 200LB and 350LB.
marcjagman
posted on 19/11/10 at 05:08 PM Reply With Quote
200lb would probably do but they're 2.25 ID.
Benzo
posted on 19/11/10 at 05:30 PM Reply With Quote
250's & 180's i run, got them from Rally design..
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 19/11/10 at 06:10 PM Reply With Quote
Could do with some 9" 180's in 2 1/4 myself
marcjagman
posted on 19/11/10 at 06:30 PM Reply With Quote
Would 200lb springs be okay for the front of a BEC?
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 19/11/10 at 07:04 PM Reply With Quote
Running 200's on my westfield but some mk's run a lot more
mark chandler
posted on 19/11/10 at 07:15 PM Reply With Quote
I have 250lb front, 200lb rear on mine, comfy on the road but a bit soft for the track I recon.
marcjagman
posted on 19/11/10 at 07:21 PM Reply With Quote
So for the front around 200-250lb and around 200lb for the rear on a BEC then? Did I mention I weigh 18 stone?
bob tatt
posted on 19/11/10 at 08:34 PM Reply With Quote
i got told 350 front 200 rear by mk for track work not got any yet was fearing a really bouncy ride on the road.
LBMEFM
posted on 19/11/10 at 11:25 PM Reply With Quote
MK's Indy run 300lbs (F) & 200lbs (R)
hobbsy
posted on 20/11/10 at 02:08 AM Reply With Quote
Hmm some of those figures seem a bit high.
BEC Furys run 180/130lb as std. I recently changed mine for 200/180 and I've just bought some 225's should I want to go stiffer on the front.
Benzo
posted on 20/11/10 at 05:14 AM Reply With Quote
ive some springs at home, 2.25" either 180's or 250's, cant remember which ones i sold before, pm me!
procomp
posted on 20/11/10 at 11:20 AM Reply With Quote
Hi
It needs a bit more info before spring poundage's can be recommended. like what sort of angle the dampers are at and where they sit in relationship to the wishbones. Without this info you could be 50Lb-75Lb out of the ballpark. IE throwing money away.
Cheers Matt
