INDY BIRD
posted on 19/11/10 at 06:08 PM |
mnr project zzr1400 update
Hi all well
The car is nearly all back together now,
fitted a new scuttle as old one was damaged, and installed all the savage switches looks good,
engine started but needs to be run up to temp now at some point to check everything,
went mad over 2 days from 9am until 11pm to get it all ready to go get flat floor set up today,
suspension was way way out castor & camber all over the place and wheel bearing bolts were loose,, been check all the bolts as i went along and
marking them but missed this one as i presumed they would be ok (silly me )
Car is alomost done as taken longer than expected to get set up Bloody rose joints and washers get on your nerves,
And the final result is the car weighed in at 520 kg with me in it at 80kg,
not bad then as this is with the car wet and 3/4 full fuel tank, should be good then,
still needs some tweeking to get spot on so left the car with them toi finish off,
1.Still to do is fit the bonnet,
2. re bleed the brakes
3.re bleed clutch,
4. run up to temp check everything for leaks and water system bleed,
5.fit fire extinguisher
6.fit rear wing protectors
7. fit areo screen
8. fit wing mirors,
9.tidy some wiring up in engine bay,
10. brake bias balance to do,
11. wire up front indicators
Thats pretty much it other than the odd cosmetic tweek and then off to the dyno in a weeks time, i wonder what bhp i will get any gueses i was hoping
for about 160+ at the wheels MMMMMM we will see
Will take some pics soon to see the car at this stage,
must say the rear exhaust we did is very quiet well pleased,
cheers all hope any winter mods are going well.
sean
daniel mason
posted on 19/11/10 at 06:25 PM |
will be interesting to see performance figures! on average, how much time do you spend on the car each week? as it seems to have taken me ages in
comparison!
INDY BIRD
posted on 19/11/10 at 06:58 PM |
well yesturday i
Fitted main tub
scuttle and dash allwired up, inclusding 7 savage switches and ignition and imobilser
front suspension brakes etc,
rear wings,
side intrusion bars
centre bar,
light bar and wired headlights
fitted exhaust system
1st bleed of brakes and clutch will let setttle and re bleed again
rear lights and wired up
started engine to check electrics
mounted rectifier/regulatore
mounted header tank
paddle shift cable re conected and adjusted
fitted new steering wheel
fitted centre console,
adjusted handbrake
mounted seat and seat belts
trial fitted nose cone
lots of cleaning and tidying as i went aswell
prob a few other little odds and ends
started at 9 finished at 11 pm so prob 2 days normal work there
good days work i try to ensure i push hard for one day a week and thats it
just get your head down put a list together you want to do and dont come in until complete thats me any way,
but i have built a couple of cars now, it used to be very daunting but now nothing really worries me it will get solved,
hope your built is going well and good luck
sean
daniel mason
posted on 19/11/10 at 07:11 PM |
i only seem to get a few hours a week and my speed is slow at best! cheers.
[Edited on 19/11/10 by daniel mason]
Johneturbo
posted on 19/11/10 at 09:49 PM |
nice one Sean thats a VERY good weight the car not you
mine with the R1 fitted was 487 with halftank gas but without me i'm about 77Kg
i'm tackling the clutch conversion on mine from cable to hydraulic so some fabriction, i've got a Busa master cylinder
so should do the job
more piccys needed sean
INDY BIRD
posted on 19/11/10 at 10:13 PM |
yep i will get some up for you asap,
also yep the busa one i hope will be ok??
i was happy with the weight i was expecting around 450-460 kg so pretty good with the zx14 in.
hope the conversion is going well
cheers
paublo999
posted on 19/11/10 at 10:22 PM |
With quaife box and freelander diff I would guess at 161bhp on a dynojet approved rolling road
If you get poor figures, check the air filter as the flat pipercross filter originally fitted to my car cost me 25bhp.
Sounds great and about 40kgs less than my car plus I weigh more than you too
My videos http://www.youtube.com/user/ninjabogeyracing
INDY BIRD
posted on 19/11/10 at 10:45 PM |
cheers paul,
yeh im a light weight i know,
Also you have a full cage and that extra oil in the acusump?? so prob would be around that extra,
I will check out the filter as i have the flat type, did you change yours then?? if so what you got buddy??
i wil prob fit a scoop anyway so could go bigger with the filter,
cheers and hope the cars going well i call you for a chat and update??
sean
oddsaabs
posted on 19/11/10 at 11:48 PM |
Sean,
Well done. Looks like the finish line is in site. Keep up the good work.
My guess is 167 at the wheels. A shot in the dark, but I'm feeling lucky today.
Jonathan
paublo999
posted on 20/11/10 at 12:07 AM |
I would suggest an ITG one, just make sure that the filter doesn't collapse when the hammer is down The good news is that the back plate will
fit and save you a load of work, so only a minute to swap the foam over.
Get rid of the reverse box and you will unleash a few more bhp too. I plan to get mine remapped with the new headers in December and will report back
with the all important numbers.
Paul
skippad
posted on 21/11/10 at 06:22 PM |
I got my Mk rolling roaded in May '09 at Dynobike, Malton.
I was suprised to see 183hp at wheels. I questioned this figure and was assured that it was correct!
So '07 zzr1400, AB billet sump, power commander, Tube Engineers 4-2-1 manifold, Mk silencer (Tube Eng.), Pipercross filter,
No reverse, fully rebuilt 3.14 Lsd (set up loose).
The comments made by tuner (forgot his name) that the exhaust manifold was the reason it was making good bhp.
I was happy!
[Edited on 21/11/10 by skippad]
paublo999
posted on 21/11/10 at 06:40 PM |
Essentially the same spec as mine and I am 161 so something not quite right somewhere. The engine standard puts out that figure at the crank? More
with ram air which we can't really replicate on the cars.
I am planning a trip to Daytuner with my new exhaust and bike can so will post in a couple of weeks with my figures.
skippad
posted on 21/11/10 at 06:53 PM |
Paul we've had this conversation before... i hav'nt got an answer to why.
Havnt you been sprinting this year? i used to enjoy following your escapades on website last year.
paublo999
posted on 21/11/10 at 07:11 PM |
Been lazy with the blog. Won my sprint class this year and going slicks next year. Will make more of an effort I promise.
