Author: Subject: Zetec Silvertop timing belt
Lars
posted on 22/11/10 at 01:58 PM Reply With Quote
Hi all
Following on from my previous post, I have bought a cheap Mk2 mondeo, which despite being a year 2000 has a silvertop zetec. (THink its been bodged in as a retro fit)
This is making getting bits a little bit of a headache, as I can't go to normal bod with reg plate and ask for parts.
The car desparately needs a timing belt change.
Could some one give me a the engine code (Is is something like ZH20??) or confirm for me what part number I am looking for.
Are all silvertops the same? Mine is a silvertop that says "Zetec" on top. I believe earlier silvertops says DOHC??
So shoudl i be able to just ask for a pre 4/98 mondeo belt?
Any ideas?
will121
posted on 22/11/10 at 03:56 PM Reply With Quote
are you sure its actually a silver top engine and not just a black top engine with the aluminium silvertop cam cover on it as they are interchangable, can you read the engine number to find a date?
Lars
posted on 22/11/10 at 04:24 PM Reply With Quote
Never thought of that. (But you are just adding to the confusion)
It does have the silvertop campulley cover too, but I guess that would be interchangable too.
I am not sure I will get to the engine number, but I will have a look at the water pump pulley, that should tell IIRC.
Lars
posted on 22/11/10 at 07:37 PM Reply With Quote
Ok deffo silvertop
one piece sump
oil filter angled down
silvertop drive belt routing
and I think the engine number flange says NGA
I will just order pre 4/98 parts, how wrong can it be...
Timing belts are overrated anyways
[Edited on 22/11/10 by Lars]
norfolkluego
posted on 22/11/10 at 09:55 PM Reply With Quote
+1 to that
I bought a blacktop back in July, I was convinced it was a silvertop because of the cam cover (it was metal). It wasn't, the water pump is the real giveaway
Lars
posted on 23/11/10 at 12:58 PM Reply With Quote
pretty sure it is silver top given the water pump and drive belt routing.
I will take the cam pulley cover off tonight, that will tell me what idlers and tensioners I need, think belt is identical between engines.
