Author: Subject: Pinto vacuum connections???
posted on 21/6/04 at 04:23 PM Reply With Quote
Afternoon All,
The inlet manifold on my 2L Pinto has a green plastic vacuum connector on the underside with 3 connections. It's is from a Capri of unkown age.
1 is marked 'D' so I'm guessing that goes to the 'D'istributor.
Any ideas where the other 2 go???
Nick
posted on 21/6/04 at 04:29 PM Reply With Quote
random guess, maybe the air filter box and the ECU?
posted on 21/6/04 at 04:35 PM Reply With Quote
Air filter box might be one, but theres no ECU!
posted on 21/6/04 at 04:42 PM Reply With Quote
yeah, i was thinking of rover turbos then... ah well! those have a feed to tell the chip what the boost is at.
jollygreengiant
posted on 21/6/04 at 04:57 PM Reply With Quote
Try, distributor, Underside of air filter (linking through to heated air duct control), and to carb.
Enjoy.
theconrodkid
posted on 21/6/04 at 05:13 PM Reply With Quote
you only need one that goes straight into the carb base ,the green thing is for use with a standard air filter
who cares who wins
pass the pork pies
posted on 23/6/04 at 06:52 AM Reply With Quote
cheers guys!
