RobC
posted on 9/12/10 at 09:03 PM |
Diffs...? ATB or Gripper plated ???
I understand how the to are different from one another but which ultimately would be the best application for hillclimbs and sprinting?...
Both are the same money...
I have an open diff and one LSD diff... so could always transfer over part from one to the other but... and this is the but... I have enough budget to
do this once for next years season...???
Anyone got experience of both that mightbe able to suggest which would be best suited to what I intend to use the car for...
Many thanks
blakep82
posted on 9/12/10 at 09:35 PM |
i would go for a ATB personally. plate diffs have different preload settings, so need to be set up. they can sometimes tend to 'snap' the
diff to lock very quickly. ATBs don't need a preload set, and they are much more progressive in their engagement
________________________
RobC
posted on 9/12/10 at 09:47 PM |
My biggest worry with the ATB is that if I hit a kerb or loose traction on one wheel this is going to make it feel very much liek an open diff...
Are gripper, TRanX plated diff's REALLY that hardcore? difficult to control would prob. be a better way to put it???
omega 24 v6
posted on 9/12/10 at 09:51 PM |
ATB is probably the best option they can be used on the road and in everyday use they allow the wheels to turn at differing rates. When the power is
on they lock up and do the job they are designed to do.
Having seen them in action IMHO they are also worth an extra 15mtrs off the line in wet circumstances. The plate ones are good but as already said
they need setup and maintained. They are also at times prone to breaking plates.
RobC
posted on 9/12/10 at 10:00 PM |
Should have also stated that my car is next year onward going to be used to 99% comp. I only took it out 3 times on the roads this year as I have just
got tired with our roads.
Hmmm... but. the big question is...
IF set up right are they not better than the ATB? My LSD has been good last year but it's the wrong ratio... and this is a chance to get a much
better setup interms of everything inline...
I think one of the biggest problems with all forms of motorsport is that I know some people are running other things that ford LSD's but they
play there hand close... And I just don;t have the money to buy both and see which I prefer.
most of the comments I have read on this and other forums are form people who have road bias cars...
The biggest thing I have found this year is that a car that I thought was awesome for track and road is in desperate need of attention to attack the
hills. Quiafe do good products but what is best for motorsport is my basic question.
Road use is something that I have no concern over.
richardR1
posted on 9/12/10 at 10:11 PM |
TranX diff would be my recommendation, my mate and i rallied a RWD R1 Mini built by Z-Cars and that originally had an ATB diff fitted. Car was used
on tarmac rallies and with the ATB in it was too easy to lose traction over rumble kerbs etc. Fitted the TranX and it was much better for the purpose
we wanted, they set the diff up for us based on the car weight and usage and it was excellent.
MK Owners Club Member 1015
RobC
posted on 9/12/10 at 10:14 PM |
This is my main worry with the ATB...
I know the ramp angles and setting differ from the TranX to the Gripper model... But how much different are they? with them both being plated...?
beaver34
posted on 9/12/10 at 11:03 PM |
I use a plated tran x item and have for the last year, it's noisy and clunky but by he'll does the car grip, I've not really had an
issue with snappiness at high speed I believe It may add understeer at lower speeds but you drive through that
JimSpencer
posted on 10/12/10 at 11:52 AM |
quote: Originally posted by beaver34
I It may add understeer at lower speeds but you drive through that
That would be a total time killer on the hills.. mid corner and exit speed is everything..
I run a quaife ATB, I personally think a plate diff that's PERFECTLY set up is probably a touch better.
But I've seen lots, and driven a few, that wern't...
If you're confident that you can get a plate diff set up spot on - to suit your style and the car - and keep it that way, then it's
probably got a smidgen of an advantage, but the quaife is simply fit and forget.
flak monkey
posted on 10/12/10 at 11:58 AM |
I had a tran-x in mine. Far, far better than an ATB (have driven cars with both fitted)
The amount of grip out of corners and in a straight line were absolutely staggering. There is one available off the shelf from Rally Design which is
the one caterham fit, so its has suitable ramp angles. After fitting it the car had far more grip than I dared to use on the road.
Yes they clonk and click when manouvering at slow speed, but its worth it.
Sera
http://www.motosera.com
