Author: Subject: Zx9r baffled sump?
littleman
posted on 14/12/10 at 01:29 PM Reply With Quote
Zx9r baffled sump?
Just wanting some advice, car is being used mainly on the road with the occasional track day on full slicks. Would it be wise to baffle the sump or is it deemed not necessary?
Should i get the sump shortened also as it protrudes quite far out and is the lowest point on the car!
Browny
Junior Builder
Posts 32
Registered 6/6/07
Member Is Offline
Photo Archive Go!
Building: Space framed Fiat Seicento with zzr1400 engine.
posted on 14/12/10 at 07:37 PM Reply With Quote
I wouldn't shorten your sump, they usually hang down quite low, say 125mm. I've had 2 cars both with zx9r engines, they are fantastic simple power plants. I have a brand new, unused baffle plate from Fluke motorsport if you want it? I have two brand new kawasaki gaskets with which to sandwich it. Additionally i also have a a brand new, still boxed EBC kevlar clutch kit.
posted on 14/12/10 at 08:28 PM Reply With Quote
If you cut the drop down part of the sump you will have to relocate the drain plug and shorten the pick up as well. It will give you better clearance and help fitting into the chassis though.
roadrunner
posted on 14/12/10 at 09:17 PM Reply With Quote
I did mine , just for peace of mind. It's not baffled and I have had no issues so far.
If you do cut down your sump, just slightly over fill with oil to compensate for lack of volume in your new sump.
chopped sump
chopped sump
littleman
posted on 15/12/10 at 01:24 PM Reply With Quote
Thanks for your replies.
I will have to think more about the shortening of the sump.
What's the opinions on a baffle plate though?
Digger Barnes
posted on 17/12/10 at 08:59 AM Reply With Quote
I bought your black zx9 powered motor. One of the first things I changed was to put a baffled billet sump on. Round here we have some of the narrow speed bumps and the sump would land on them every time.
So my advice would be if you are using it on the road chop it.
[Edited on 17/12/10 by Digger Barnes]
littleman
posted on 17/12/10 at 01:40 PM Reply With Quote
Where did you get that from mate and how much?
Digger Barnes
posted on 18/12/10 at 03:11 PM Reply With Quote
I bought a spare engine which someone had been building to a high spec and then gave up. So I got it for a song, a bit lucky really.
I believe these guys do one for about £190 Cliky Clicky
I am sure there are others, someone here will know.
