New Topic New Reply
Author: Subject: Krypton unit - how big
r1_pete
posted on 16/12/10 at 09:19 PM Reply With Quote
Beaver34's thread on carb tuning got me thinking, so did a quick search and found TI KRYPTON 312 ENGINE ANALYSER NO RESERVE on eBay (end time 17-Dec-10 15:39:12 GMT), not far from me and I'm sure it will go in the L200, but can anyone give me an idea how big these things are? looks to be about the size of a tool cabinet then the overhead arm.....
adithorp
posted on 16/12/10 at 09:47 PM Reply With Quote
Got one in my workshop. I'll measure it tommorow. From memory the main unit is approx 30"x14"x18" (WxHxD). I don't have the cabinet though.
http://jpsc.org.uk/forum/
marcjagman
If it's the model I'm thimking of about 5-6 feet tall 3 feet wide and about 2-3 feet deep.
theconrodkid
posted on 16/12/10 at 09:51 PM Reply With Quote
about the size of a crt telly.
looks about 60,s tho and of little use on anything remotley modern or complicated,just about handle points dwell,timing,volts and amps.
you can get things that do more that fit into your pocket.
i dumped a much better/bigger/later one than that when a part failed and we couldnt get replacement as itr was too old
who cares who wins
pass the pork pies
omega0684
posted on 16/12/10 at 10:28 PM Reply With Quote
are youplanning on killing superman?
l0rd
posted on 16/12/10 at 10:32 PM Reply With Quote
Is that for a steam engine?
zetec mike
posted on 16/12/10 at 10:52 PM Reply With Quote
Not sure its much use on anything modern, its an old analogue model, doesnt look like its got a scope or gas analyser. Only really any good for setting up / diagnosing ignition on anything with points / condensor and a dizzy but not much else. Timing light may be of use but thats a lot of workshop space !!
adithorp
posted on 16/12/10 at 11:30 PM Reply With Quote
As has been said, it's only any use on classics and needs a CO meter used with it for the best results. It comes in usefull (very) occationally.
Without the stand it's small enough not to take up too much space and for me to keep. It's small enough to carry (handle on top) with one hand... just.
r1_pete
posted on 17/12/10 at 08:00 AM Reply With Quote
OK Thanks all, thought it might be usefull for keeping the E Type in tune, but if it doesn't have a CO meter built in its no good, I'm on MJLJ ignition, so I guess it offers less than the vacuum gauges, timing light, colourtunes and PC I use now.
Cheers, some money and space saved.
adithorp
posted on 17/12/10 at 08:27 AM Reply With Quote
Just for the record... Smaller than I thought 24"x10"x12"
thunderace
posted on 17/12/10 at 12:57 PM Reply With Quote
i got a mini one new on ebay its about 30cm x20cm x20cm cost around £40 ,never used it as i dont have a clue how it works lol just looked good lol
beaver34
posted on 17/12/10 at 05:03 PM Reply With Quote
you can sort my engine then!
New Topic New Reply
