Author: Subject: Making gauge holes in ABS sheet?
leemarkadams
posted on 19/12/10 at 07:35 PM Reply With Quote
Hello all, started to make the new dash today and just wonder what the best way to cut the holes for the extra gauges (oil pressure and fuel level) is?
Lee
blakep82
posted on 19/12/10 at 07:48 PM Reply With Quote
hole saw
________________________
r1_pete
posted on 19/12/10 at 08:24 PM Reply With Quote
Tank cutters work fine on such plastics, not too expensive from B&Q and the likes.
trextr7monkey
posted on 20/12/10 at 12:18 AM Reply With Quote
As above, it is really soft stuff to work so even a big hole witha Forstner bit or similar and a few minutes witha half round file will do the job.
James
posted on 20/12/10 at 03:25 PM Reply With Quote
Hole saw probably the best way.
But cheapest probably is to chain drill it with a 1-2mm drill bit and use a file.
HTH,
James
leemarkadams
posted on 20/12/10 at 04:32 PM Reply With Quote
Thanks all, used a hole drill bit and got them done today.
Lee
