Author: Subject: Vivaro boost sensor
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/12/10 at 07:36 PM Reply With Quote
Vivaro boost sensor
Best place to get a boost pressure sensor for my Vivaro 1.9cdti
froggy
posted on 28/12/10 at 08:47 PM Reply With Quote
is it not the hose split down by the turbo? had loads of them with boost sensor codes nearly always split pipe on the back of the head
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/12/10 at 08:53 PM Reply With Quote
Will give it a look but occasionally it will boost fine other times nothing .
[Edited on 28/12/10 by CRAIGR]
Cousin Cleotis
posted on 28/12/10 at 10:28 PM Reply With Quote
Is this the type with a remote sensor and hose from the back of the manifold? If so ive had a few blocked, clear out the pipe on the back of the manifold with a drill bit before fitting a new sensor.
Pull the hose of the back of the manifold hold your finger 1/2" away from the outlet and get someone to rev the engine to confirm.
Paul
woolly
posted on 28/12/10 at 10:41 PM Reply With Quote
next to it on mine is the turbo boost controller (real name ?)with vac pipes that can play up. and some times the variable veins in the turbo seize.
last time i was chasing that fault it was a hole in the intercooler
woolly
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 31/12/10 at 09:42 AM Reply With Quote
Thanks guys will be checking all the above at the w/end
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 1/1/11 at 10:04 AM Reply With Quote
Have now cleaned this out and it was blocked solid at the manifold as you said Paul , unfortunately it made no noticeable difference so the search continues. lol
Paul
