trialsman
posted on 5/1/11 at 03:53 AM |
How do you shorten a hand brake lever?
I've seen a post on this here before but I can't find it now. My hand brake lever is too close to my gear shift in 2nd and 4th on my 79
Escort Mk2 Locost. How can I take about 5cm out of the overall length of it without messing it up. Thanks in advance, Russ
MakeEverything
posted on 5/1/11 at 09:01 AM |
Any Photos? Youll need to cut and shut it, or cut it and weld a piece of heavy gauge barrel into the handle.
Kindest Regards,
Richard.
posted on 5/1/11 at 10:00 AM |
Could you move it further back on the tunnel top?
steve m
posted on 5/1/11 at 10:13 AM |
If you shorten it, you will also lose out on leverage
pekwah1
posted on 5/1/11 at 10:38 AM |
he probably doesn't have girly arms like you though steve so can deal with the leverage
indykid
posted on 5/1/11 at 10:55 AM |
but if you're modifying it, you can change the lever ratio on the other side too. you'll gain stroke, but how often do you have the
handbrake on?
i assume you'd just cut out as much as you need from the outer sleeve, cut the same from the inner rod, then weld it back together. for the
forces it'll see, it won't need sleeving as long as you can weld.
steve m
posted on 5/1/11 at 11:32 AM |
hhahahaha
Girly arms. pah !
shouldnt you be out in that freezing cold garage waving spanners about ?
Im in mine, heater is on, and the cricket on telly, nice cup of tea
not much more work to do before the MOT, (dig)
pekwah1
posted on 5/1/11 at 01:23 PM |
just been out there all morning actually!
i have some engine mounts!
Andybarbet
posted on 5/1/11 at 07:49 PM |
Luegos build diary had a how to on this, i have a copy somewhere but not sure where, maybe ask in the Luego section and you might find someone a tad
more organised than me
