<<  1    2  >>
Author: Subject: Help! My flywheel doesn't fit!
pekwah1
posted on 7/1/11 at 01:48 PM Reply With Quote
Hi Guys
I have removed my xflow in favour of a silvertop zetec.
The problem i have at present appears to be that my flywheel doesn't fit in the gearbox!
I'll be honest and say i don't know exactly what the flywheel is, but believe it to be a zetec one, and the gearbox is a 5 spd type 9.
I thought that the zetec running gear was supposed to fit straight in, or am i supposed to grind some extra off the bellhousing?
Pics below.
Thanks,
lotusmadandy
posted on 7/1/11 at 01:51 PM Reply With Quote
That looks like a 2.0 flywheel,they dont fit inside a standard type9
bellhousing.
You need the flywheel from a 1.8 to mate them up.
pekwah1
posted on 7/1/11 at 01:52 PM Reply With Quote
from a search on the number (928M6398) stamped on the flywheel i'm getting a 1.8 flywheel....?
lotusmadandy
posted on 7/1/11 at 01:56 PM Reply With Quote
I have a couple of spare 1.8 flyweels in the garage.
I'll just nip out and check....
pekwah1
thanks very much!
femster87
posted on 7/1/11 at 02:04 PM Reply With Quote
bellhousing.
Really, I have not mated mine up yet. but did not know that.
lotusmadandy
Ok,from both 1.8 flywheels i get the no........928M 6398AG
From both 2.0 flyweels i have i get the no...928M 6398CB
Hope this helps,
pekwah1
posted on 7/1/11 at 02:05 PM Reply With Quote
not at all, mine's a 928M 6398 AE!
Thanks anyway!
lotusmadandy
posted on 7/1/11 at 02:10 PM Reply With Quote
I dont want to sound stupid or anything but is that defo
a standard type9 bellhousing?
Again i have a couple and it doesnt look like either.
pekwah1
posted on 7/1/11 at 02:20 PM Reply With Quote
well that's the other consideration i guess... i know little about them tbh.
It was mated to a crossflow before i removed it, otherwise i know that it's a 5 spd.
Are there stamps or something somewhere on the gearbox/bellhousing to identify it?
lotusmadandy
posted on 7/1/11 at 02:27 PM Reply With Quote
Cast into the rear bottom face of the housing is,71BB 7505AC
Bumble
posted on 7/1/11 at 02:28 PM Reply With Quote
What release bearing do you have fitted. For a zetec to type 9 you need the CTT133 release bearing.
Matt
pekwah1
posted on 7/1/11 at 02:32 PM Reply With Quote
i don't know what the release bearing fitted is but i'm well aware of the need for the 133!
i'll check the casting on the bell housing.....
pekwah1
deezee
posted on 7/1/11 at 02:54 PM Reply With Quote
Your flywheel part number is off a 1.6L Zetec engine. This may explain a few things.
posted on 7/1/11 at 03:02 PM Reply With Quote
Looks like an ali bellhousing? Looks different to a type 9.
I may be wrong but if it came with the crossflow its a type 4 bellhousing or something special.
JeffHs
posted on 7/1/11 at 03:14 PM Reply With Quote
That looks like a MK2 RS bellhousing with the clutch lever side chopped off. In standard guise the bell is symetrical and the clutch is operated by a cable through the front of the case,
It looks like someone has chopped off the bulge, left it open at the side, and welded in a straight piece to make good on the mounting face
pekwah1
posted on 7/1/11 at 03:15 PM Reply With Quote
it is an ali bellhousing, can't see any signs of any welding on it though...
nige
posted on 7/1/11 at 03:19 PM Reply With Quote
im no expert , but i can see the bottom weld
on the left of pic
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
JeffHs
posted on 7/1/11 at 03:24 PM Reply With Quote
http://wiki.retro-rides.org/(S(51duebaleztbsz45fqdyhmjc))/Type%209%20Conversion.ashx
Have a look here for bellhousings - fitting a type 9 into a MK2 Escort
posted on 7/1/11 at 03:28 PM Reply With Quote
What u need is type 9 bellhousing, standard cast one which go for nothing regular on here or a new ali job from the the likes of retroford, burtons etc, circa £200
pekwah1
posted on 7/1/11 at 03:35 PM Reply With Quote
oh balls, looks like i need a bellhousing then.
Anyone got one spare? cheaper the better!
omega0684
posted on 7/1/11 at 03:45 PM Reply With Quote
Cast type 9 bell housing you can get for pennies!
Ali one's though are difficult to find on ebay, new they are about £200, i did get mine off ebay for about £90. the escort bell housing which have 2 starter motor spaces will also fit
pekwah1
posted on 7/1/11 at 03:46 PM Reply With Quote
is £26 pounds reasonable for a cast housing?
i've found one where i live....
loggyboy
posted on 7/1/11 at 04:25 PM Reply With Quote
Should have a type 9 connected to it for that! lol
<<  1    2  >>
