Author: Subject: Turned parts - new guide prices
flak monkey
posted on 19/1/11 at 12:18 PM Reply With Quote
New year, new prices...infact most are reduced! Now theres a novelty!
Prices are guides and based on previous work I have completed for other people. Give me a shout if there is anything you want....
Aluminium pulleys are all made from 6063-T6 aluminium
Steel threaded inserts (for wishbones etc) from £1.50 ea
Aluminium crank pulleys for poly vee belts from £75
Aluminium water pump pulleys for poly vee belts from £50
Steel idler pulleys with bearings and spacers from £35
Aluminium alternator pulleys for poly vee from £45
Convert your older engine to run polyvee aux belts using a combo of my pulleys
Shock absorber spacers from £1 ea in steel or £2 ea in stainless...no more stacks of washers!
Rose joint spacers from £1.50 ea in steel or £2.25 in stainless
Aluminium hubs from £175 pair
Hubcentric wheel spacers/stud adaptors from £50 pair
Aluminium gear knobs £15 ea
Basically anything you like, no job too small...
Sera
http://www.motosera.com
nib1980
posted on 19/1/11 at 12:36 PM Reply With Quote
not right now but in the future i'll need a propshaft spacer, between my live axle and prop.
i presume this is something you could do?
flak monkey
posted on 19/1/11 at 02:07 PM Reply With Quote
Yep, no problem. Just need dimensions thats all
Sera
flak monkey
posted on 20/1/11 at 06:49 PM Reply With Quote
Some sample photos
Sera
flak monkey
posted on 30/1/11 at 10:07 PM Reply With Quote
Bump
Sera
damdy-cash
posted on 31/1/11 at 07:39 AM Reply With Quote
looks veeery nice!!
Could you do a set of pulleys for the Zetec silver top as well?
cheers Volker
