Author: Subject: Superglue Aluminium
liam.mccaffrey
posted on 20/1/11 at 03:13 PM Reply With Quote
Superglue Aluminium
Any tried to superglue 2 pieces of Ali together?
I failed miserably just wouldn't take. apparently its a well know fact
that you can't superglue ali
Any one else know this??????
Build Blog
Build Photo Album
posted on 20/1/11 at 03:26 PM Reply With Quote
Probably to do with the oxide layer. It epoxies quite well though especially if you abrade the oxide layer off.
posted on 20/1/11 at 03:30 PM Reply With Quote
3M double sided tape/sheet is the solution!
We make some ally facia panels at work and use this method to bond the inner and outer skins together. Surfaces must be clean and grease free and you only get one attempt at positioning the parts together (we use assembly jigs). Once stuck you will not get them apart without completely wrecking them.
I can probably acquire a sheet of the 3M sheet (A4 sized) if you want to have a go.
liam.mccaffrey
posted on 20/1/11 at 03:47 PM Reply With Quote
I'm not needing to it, just noticed in work that you can't glue aliminium cans together. If I was doing it on the car I would bond it with something much better than Superglue
Build Blog
Build Photo Album
matt_gsxr
posted on 20/1/11 at 04:34 PM Reply With Quote
quiet day?
MakeEverything
posted on 20/1/11 at 04:38 PM Reply With Quote
Sad git!
Kindest Regards,
Richard.
RazMan
Another vote for 3M tape. I used to stick brackets to alloy road signs - once positioned you will tear the metal trying to get them apart.
Raz
blakep82
posted on 20/1/11 at 04:44 PM Reply With Quote
ah, trying to make a can tower? nice
i made one that reached the ceiling last year. that was a good day
________________________
HowardB
posted on 20/1/11 at 05:18 PM Reply With Quote
yes - well known im aerospace too. the accepted adhesive is high temp cure epoxy.
hth
Howard
Howard
Ian Pearson
posted on 23/1/11 at 05:12 PM Reply With Quote
Provided you remove the oxidation prior to application, HAFIX should do it.
