Author: Subject: anyone know anything about pressure - enthalpy charts?
Miks15
posted on 20/1/11 at 11:22 PM Reply With Quote
Right ive got a pressure enthalpy chart, and i need to know the enthalpy of the fluid at given pressure and temperatures.
But im not sure what lines to use, can anyone help? here is the chart:
So say for a pressure of 2 bar at 80 degree C, what would the enthalpy be?
Please help
Miks15
posted on 20/1/11 at 11:29 PM Reply With Quote
And also what are the two sections for, is it something to do with saturation, because at 80 degree its a vapour, whereas at 20 its not, and i think i need to read off to different parts of the graph for that :S
keithice
posted on 21/1/11 at 12:28 AM Reply With Quote
yes, what do you need to know? keith(fridge/aircon engineer, hence the ice),
Smile and wave boys.... Smile and wave....
Miks15
posted on 21/1/11 at 12:38 AM Reply With Quote
keith if you can help i would owe you big time.
Basically we have done an experiment at uni (i saw we, the post grad did it, we just took down the results, he then sent us on our merry way) and i now have to right up the lab report. We have to work out thermal efficiency of the practical rankine cycle on a small scale test. So i need to know the enthalpys at 4 different points (between the 4 different processes) so i can work out the heat transfers from source and to the sink, and also the work out at the turbine, and in from the pump.
I have pressures and temperatures.
So for example i have for the first set of results:
Before Vapour generator : abs pressure - 3 Bar, temp 18.5 C
After vapour generator : abs pressure - 3 Bar, temp 83 C
after turbine, before condenser - 1.05 Bar, and i assume still 83C
after condenser, 1.05 Bar, 17.5 C
Can you give me a hand indetifying the enthalpys for these values?
keithice
posted on 21/1/11 at 12:59 AM Reply With Quote
miks are you using the posted chart?
Miks15
posted on 21/1/11 at 01:01 AM Reply With Quote
yes thats the one weve been given
Miks15
posted on 21/1/11 at 01:02 AM Reply With Quote
keith, would it be easier if we both go on the chat function of the site? might be easier than back and forth posting
keithice
posted on 21/1/11 at 01:06 AM Reply With Quote
yes but not used it before
Alan B
posted on 21/1/11 at 01:36 AM Reply With Quote
What?...and deprive us of this scintillating discussion???
Seriously guys we may learn something...certainly takes me back a few years
keithice
posted on 21/1/11 at 01:46 AM Reply With Quote
sorry alan... ended up on the phone as it was easier to try and explain it and of course it's a turbine not a compressor (which I would be using...) but I think mik15 cracked it....
Miks15
posted on 21/1/11 at 02:13 AM Reply With Quote
i think i have cracked it now, locostbuilders to the rescue
Just proves you should never leave assignments til the night before... especially when you dont fully understand the assignment
Couple more hours and it should all be done... then i can finally go to bed!
mcerd1
posted on 21/1/11 at 08:13 AM Reply With Quote
sounds like your doing second year mech eng (or first year south of the border)
I'm glad someone else answed this, I'd have had to get my old thermodynamics books out (and I hated thermodynamics)
big-vee-twin
posted on 21/1/11 at 09:18 AM Reply With Quote
Good old Eastop & Mconkey
http://www.triangleltd.com
SeanStone
thermodynamics
mcerd1
posted on 21/1/11 at 09:36 AM Reply With Quote
thats the one
Miks15
posted on 21/1/11 at 10:39 AM Reply With Quote
yep im second year
Really should have started this assignment sooner! I will learn for next time.
5 in the morning is not a time i want to be finishing a piece of work!
