Author: Subject: Bits of pipe wanted
trikerneil
posted on 23/1/11 at 08:38 PM Reply With Quote
Bits of pipe wanted
As title.
I'm after 4 pieces of 1-1/2 nominal bore Sched 160 stainless pipe by 18mm long.
Can anyone suggest somewhere that may be able to help?
Thanks in advance
Neil
ACE Cafe - Just say No.
madteg
posted on 23/1/11 at 09:13 PM Reply With Quote
you could always bore a piece of solid bar
mattyc
posted on 23/1/11 at 10:14 PM Reply With Quote
You will struggle to get stainless in sch 160. What's the application I may have sch120 low temp a333 c/s at work.
Chippy
posted on 23/1/11 at 11:06 PM Reply With Quote
I have a few bits of 15/8" O/D S/St pipe that I had to make up my exhaust. No idea what Sched it is, but should be around 11/2" ID or nearly so. Yours if any good. Cheers Ray
trikerneil
posted on 24/1/11 at 06:17 AM Reply With Quote
They're for the clamp spacer rings at the head end of a bike engine exhaust so the grade isn't important only rustlessness.
They would be 48mm od by 34mm id (ish).
It would take forever to bore out solid SS bar on my modelmakers lathe
Thanks anyway chaps.
Neil
daviep
posted on 24/1/11 at 09:01 AM Reply With Quote
I'll see if I've got any of the material I used. It was too big on the ID but I knocked 4 pieces of tig wire into the gap to centralise it and it left a perfect gap for welding.
Davie
hughpinder
Just a thought: wouldn't it be easier to get 20mm*3 strip and bend it to make your brackets?
Regards
Hugh
trikerneil
posted on 24/1/11 at 05:32 PM Reply With Quote
Thanks Davie
Putting tacks in the bore never occurred to me. Doh!
Neil
daviep
posted on 29/1/11 at 06:40 PM Reply With Quote
Hi Neil,
Sorry for the delay, today was the first of me getting to the garage. Unfortunately I can't find any of the pipe I used, I've been trawling through my emails trying to find the invoice for the sizes but again I've drawn a blank. Sorry
Regards
Davie
EDIT for typo
[Edited on 29/1/11 by daviep]
trikerneil
posted on 31/1/11 at 08:25 PM Reply With Quote
Thanks for looking, you've given me an idea anyway.
Neil
