<<  1    2  >>
Author: Subject: Correct English word for this?
maartenromijn
posted on 27/1/11 at 09:42 AM Reply With Quote
What would de the correct English word for this tool?
BLOG: http://thunderroad-super7.blogspot.com/
liam.mccaffrey
posted on 27/1/11 at 09:48 AM Reply With Quote
we call them floggers, just looked it up in the brammer catalogue and its proper name is a slogging spanner
[Edited on 27/1/11 by liam.mccaffrey]
Build Blog
Build Photo Album
tomgregory2000
posted on 27/1/11 at 09:51 AM Reply With Quote
metric ring slogging spanner
maartenromijn
Thanks. We don't have that kind of info in the Netherlands.
Flamez
posted on 27/1/11 at 10:06 AM Reply With Quote
I guess you smack it with a hammer, my type of tool lol.
my build mac1motorsports
daviep
posted on 27/1/11 at 10:36 AM Reply With Quote
Everywhere that I've worked they have also been called flogging spanners.
Davie
Xtreme Kermit
posted on 27/1/11 at 12:19 PM Reply With Quote
What a novel idea...
A spanner designed to be hit with a hammer
[Edited on 27/1/11 by Xtreme Kermit]
mad4x4
posted on 27/1/11 at 12:25 PM Reply With Quote
If the offshore world ( Aberdeen and the likes) these would be flogging spanners
Scot's do it better in Kilts.
James
posted on 27/1/11 at 12:54 PM Reply With Quote
Well! You learn something every day. Never heard of or even seen them before!
James
owelly
I used to use these flogging spanners on a daily basis until the health and safety brigade saw them. They've been banned by the H&S for almost everything they were intended for!!
http://www.ppcmag.co.uk
bi22le
posted on 27/1/11 at 01:11 PM Reply With Quote
Huh, never seen one of those before either.
Please read my ring story:
liam.mccaffrey
posted on 27/1/11 at 01:12 PM Reply With Quote
Seriously? Must check that out as they are used all the time here!
Build Blog
Build Photo Album
yozza
posted on 27/1/11 at 02:35 PM Reply With Quote
Hi
We use them a lot offshore as mentioned above. They are supposed to be used when tightening with a machined recess, usually with a gasket between (valve flanges etc) the idea being you hit it until the note changes to a 'ring'. This tells you that both flanges are metal to metal and the machined recess is compressing the spiral wound gasket correctly. Torque bars or torque multipliers are the more acceptable method but using a big hammer with these is much more fun!!
Joe
maartenromijn
posted on 27/1/11 at 03:06 PM Reply With Quote
We use them at our ship repair yard. I needed the proper word in order to write my report in English.
posted on 27/1/11 at 04:20 PM Reply With Quote
I've not seen one of those for a long time. They were flogging spanners here as well. Is it still Christmas there Marten? I never heard them called slogging spanners. There's a link to some here.
[Edited on 27/1/11 by Peteff]
TPG
posted on 27/1/11 at 05:55 PM Reply With Quote
We used to use them to tighten the top nut on 36" (Yes-3 foot) pumps when I was an apprentice. It was the apprentices job. Stood there swinging with a large sledge hammer untill the Fitter said "Okay". Then "You can undo it now,Don't be such a cheeky (^%*** in the future." Couldn't lift your arms above the shoulder after doing them.
Happy days.
..Which was nice..
perksy
posted on 27/1/11 at 06:27 PM Reply With Quote
Last time i used one of those it ended in Tears
Think i've still got the scar..
Nash
posted on 27/1/11 at 08:00 PM Reply With Quote
In petro-chem industry they have copper version to hit with copper hammer intringically safe (no sparks).
Tend to be used on 1" plus only Never seen a 2BA flogging spanner
..............Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
maartenromijn
posted on 28/1/11 at 01:17 PM Reply With Quote
Originally posted by Peteff
Is it still Christmas there Marten? [Edited on 27/1/11 by Peteff]
No Christmas, but I cannot tell the ladies goodbye...
mcerd1
posted on 28/1/11 at 01:46 PM Reply With Quote
you can also stick a bit of tube over the end of it and just use it like a giant spanner (obviously it needs to be a fairly strong / close fitting tube)
the last time I saw them using a bar ~1.5m long
I'd never seen untill a year ago when I had to start designing structures that needed M42 bolts to hold them to the ground
and aparently it hard to get 65mm spaners.....
gazza285
posted on 28/1/11 at 05:44 PM Reply With Quote
Use them all the time, they're in the van next to the podgers.
Angel Acevedo
posted on 1/2/11 at 05:12 PM Reply With Quote
Sorry,
Late to the party:
Correct name would be "Flat Flogging Spanner"
As oppossed to "offset" ones
AA
posted on 1/2/11 at 05:28 PM Reply With Quote
Originally posted by Angel Acevedo
Sorry,
Late to the party:
AA
Could be yet another nick name for Max Mosley
posted on 1/2/11 at 05:30 PM Reply With Quote
When you get bolts that big i tends to be hydraulic bolt stretchers that are the weapon l of choice.
mcerd1
posted on 1/2/11 at 06:44 PM Reply With Quote
I think they were just going get a big 1" drive socket / torque wrench - they are only 8.8's not HSFG's so they don't need to be that tight and we use locknuts just to be sure they don't work loose (well you wouldn't want 50tonnes of steel landing on your head )
but the standard just says "tightened with appropriate spaners" and give no other guidance
<<  1    2  >>
