John P
posted on 29/1/11 at 10:00 AM |
Do any Stud Finders actually work OK?
About a year ago I bought a cheapish own brand stud-finder from B&Q but it's virtually useless. If you look for a stud it beeps at one
point but then if you try it again in the same location you get a totally different response.
It also supposedly finds burried cables but again I've found it so vague that I can't rely on the results which can be a bit un-nerving
when drill into a wall blind. (Obviously I wouldn't drill immediately over or to the side of a known fitting).
Are there any sensibly priced units that anyone can recommend?
John.
loggyboy
posted on 29/1/11 at 10:13 AM |
I have a BnQ one, lil black triangle, works pefectly for me.
posted on 29/1/11 at 10:27 AM |
I have a cheapo Ebay special with a big metal hoop on the end. Works nicely. Even has a row of LEDs on the end so you can see the thing getting
"closer".
tegwin
posted on 29/1/11 at 10:36 AM |
I find a nuckle tapped on the wall is a good way of getting close.... then use a small screwdriver to push through the plasterboard until you pinpoint
the exact location of the stud... You will need some polyfiller however :p
www.verticalhorizonsmedia.tv
Theshed
posted on 29/1/11 at 10:40 AM |
In relation to knuckle rapping ....I am told by a female friend that something called a "rampant rabbit" is the proper tool for the
job......
HowardB
posted on 29/1/11 at 10:45 AM |
my female friend tells me the rampant rabbit is instead of a stud, not to find one!
Howard
mad4x4
posted on 29/1/11 at 12:14 PM |
We have a cheapish one and it works reasonably - need to read the instructions. But yeah seems to work. Think ours is Champion make - ??ARGOS??
Scot's do it better in Kilts.
ruskino80
posted on 29/1/11 at 12:23 PM |
just did a nice cold mains water repair yesterday after my customer drilled clean into the pipe after having used one of these finder gadgets.he now
has a large hole in his recently tiled cloakroom wall a nice bill from me and the tiler booked to sort it out!!
John P
posted on 29/1/11 at 03:03 PM |
Been looking on-line and most seem to get a pretty poor revue. Have seen some suggestions the Ryobi SW109TL may be OK. Anyone used one of these?
posted on 29/1/11 at 05:10 PM |
His worked then
Ninehigh
posted on 29/1/11 at 07:41 PM |
Mine doesn't work because it just goes off in the presence of me
Can't believe no-one's said that yet!
MikeR
posted on 29/1/11 at 11:23 PM |
i've seen a bosch one that appears to work well, about 50 quid on ebay so not cheap.
