Author: Subject: Garage Clearout
Lundy
posted on 30/1/11 at 08:54 PM Reply With Quote
Garage Clearout
Helix 7 1/4" (184mm) race clutch. Cover part number 63-211R (now 63-210R) which will handle 205ftlb of torque - more in a light car such as a Westfield/Caterham. Plate part number 56-1001 has 1" x 23 splines so suitable for a Ford gearbox. The unworn thickness of the plate is 7.2mm and I have measured today it at 6.99mm. The minimum thickness is 6.3mm so you can see that there is plenty of meat left on it.
7 ¼” (184mm) XE Flywheel skimmed and has the starter ring.
All parts are in excellent condition and ready to go. £300 + postage
I was going to convert my X-Flow to dry sump but I have now changed the engine to an XE so I have the following for sale.
X-Flow dry sump has some dents and marks but is water tight, included also is a Burton Power Products bottom end gasket set. £85 + post
X-Flow Cosworth 5 port dry sump pump. £75 + post
Westfield exhaust part No. 1712001 F2 HB (Not re-packable) only fitted to an engine for 10mins but I decided it was too much work to get it to fit my narrow body. £100 + post
Westfield Narrow body seats with adjustable runners. Small tear on driver’s seat and slight marks around head rest mount a patch on passenger seat which does not show when fitted. They have only done 1500 miles since being fitted and the passenger seat has hardly been sat in. Also available if required are some head restraints that I made up in order to pass the IVA. First picture is from a Westfield brochure. £100 + post
Westfield standard chromed roll over bar, slight corrosion in the chrome around the mounting plate, free to anyone who wants to put it to good use.
Westfield 12” steering wheel and boss used to pass the IVA. £30 + post
Filter King pressure regulator and braided fuel line £25 + post
Driveshaft fitted to a narrowbody with a 2000E box to an escort live axle 700mm in length good condition £50 + post
Facet fuel pump used but in good condition £10 + post
Indicators used to get a narrowbody through the IVA test, motor bike indicators with nylon extensions and mounting bolts. £15 Delivered
IVA compliant bonnet catches used for the IVA test £20 delivered
Please feel free to email me any questions
Chris
gavin174
posted on 30/1/11 at 09:03 PM Reply With Quote
u2u sent
adrianreeve
posted on 30/1/11 at 09:43 PM Reply With Quote
U2u sent!
Adrian
computid
posted on 30/1/11 at 09:45 PM Reply With Quote
U2U'ed RE: Rollbar
slingshot2000
posted on 30/1/11 at 10:25 PM Reply With Quote
U2U'ed regards steering wheel.
Daddylonglegs
posted on 30/1/11 at 10:37 PM Reply With Quote
u2u sent
RobLyon
posted on 30/1/11 at 10:41 PM Reply With Quote
Where in the country are you? Could be interested in the seats. Can you measure the mounting holes?
NigeEss
posted on 30/1/11 at 11:02 PM Reply With Quote
U2U re: the Facet pump.
