Author: Subject: 1300cc pinto engine?
t16turbotone
posted on 9/2/11 at 07:07 PM Reply With Quote
i think i know the answer but here goes.......anyone got one or know where i could get one
cheers
Tony
steve m
posted on 9/2/11 at 07:15 PM Reply With Quote
I was not aware that ford ever produced the pinto (ohc) in a 1300
[Edited on 9/2/11 by steve m]
DRC INDY 7
posted on 9/2/11 at 07:26 PM Reply With Quote
They are very rare not many about only ever seen one that was in 1989 in a 1985 b reg mk1 sierra I worked on it and drove it very under powered
[Edited on 2/9/2011 by DRC INDY 7]
Puddle Dodgers Club
mookaloid
Pretty sure they did
linky to burtons
steve m
posted on 9/2/11 at 07:28 PM Reply With Quote
I stand corrected,
(embarrassed)
omega0684
posted on 9/2/11 at 07:29 PM Reply With Quote
tony what do you want one for? i have a 2 litre sat in the garage
mcerd1
posted on 9/2/11 at 07:45 PM Reply With Quote
I think they were almost all in the continental mk1 sierra's and not very common at that - I'd probably start looking in germany...
but I've got to ask why you'd want one ?
posted on 9/2/11 at 08:01 PM Reply With Quote
I knew Fords made a 1300 Pinto but I've never seen one even in left hand drive Taunus's or Sierra's
ssc28
posted on 9/2/11 at 09:48 PM Reply With Quote
Have owned 2 of them, both were 3 doors and both were mk1 sierras an A and a B registration. Bought both to take the diff from them, they had 3.77:1 ratio diffs which are sought after in oval racing circles. If you guys think a 3.18 diesel diff is hard to get try finding a 3.77 it's even harder. Sold cylinder heads to other racers to use on 1600 pintos as they could increase the compression ratio without needing to have machining done to the 1600 heads (illegal mod in their class but impossible to tell without stripping the engine).
If you can find a 1300 now you'll easily get £500 for the diff from your local stock car racer.
DarrenW
posted on 10/2/11 at 01:57 PM Reply With Quote
Sierra Mk1 3 Door Rolling shell -- Cosworth, XR4, Ford on eBay (end time 15-Feb-11 19:37:35 GMT)
Sadly no engine but might have the diff. Quite cheap too for such a rare motor. Can you imagine that one day one of these might be worth as much as a mk1 Escort!!!!
[Edited on 10/2/11 by DarrenW]
ssc28
posted on 10/2/11 at 09:39 PM Reply With Quote
It wont have a rare diff Darren, he says it was a 1600 originally so it should probably have a 3.62:1 in it. Stll it's a rare shell these days so it will interest someone.
