Author: Subject: FS: Wizards of NOS SB150i4 direct port injection nitrous oxide kit & Bottle heater
maximill666
posted on 13/2/11 at 12:32 PM Reply With Quote
I have for sale a Wizards of NOS SB150i4 direct port injection nitrous oxide kit.
This was fitted to my MNR VortX R1 Turbo and removed when I sold the car.
Parts Included:
· 4 x Crossfire Injectors.
· 1pr x Billet alloy Pulsoids with CNC machined SS fittings and laser cut mounting plates.
· 1 x 5 lb bottle with Max-flow Valve & SPRV.
· 1 x Combined 4 way distribution block
· 1 x Fuel adapter.
· 1 x Electronic Throttle position sensor upgrade.
· 1 x Arming switch w/ aircraft style cover.
· 2.5M of 5mm high pressure micro bore nylon nitrous supply pipe with nuts & olives.
· 4mm nylon fuel supply pipe.
· 4mm nylon supply lines from Pulsoids to injector.
· 1pr x Metering Jets
· Fitting instructions
I can also give full instruction on how to fit & set up
Kit would currently cost £765 inc the vat mans cut plus delivery from Highpower systems
The kit is perfect working order, comes ready to install , but the only thing missing is a bracket to hold the bottle but these can be obtained very easy, or you could make one & a little bit of cable to wire it up.
I'm looking for £300 collected or if buyer wants to arrange own courier I will box up no probs
I've also got a Wizards of NOS black night bottle heater for sale, photo at the bottom
In perfect condition, Cost £175 I'm looking for £100
Or the kit plus bottle heater for £350
Located in liverpool
maximill666
posted on 18/2/11 at 08:50 PM Reply With Quote
SOLD
