Author: Subject: pinto from a transit ?
dave r
posted on 21/2/11 at 06:21 PM Reply With Quote
how do you tell if its a transit low compression ?
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
t16turbotone
posted on 21/2/11 at 06:35 PM Reply With Quote
I think the low compression engine was marked up 202 on the cylinder block, if ime wrong someone will be along to correct me
tony
snapper
posted on 21/2/11 at 07:19 PM Reply With Quote
Not 202, 202 is a Cosworth block.
I used a Transit low comp engine, it was marked 205.
The only way to tell is to remove the head and look at the pistons which will have LC on them.
If you can't see LC due to carbon then measure the difference between deck height and piston, anything over 0.5mm is low compression.
If you have to remove pistons I would recomend fitting the injection rods and deck the block flush with a new set.
I eat to survive
I drink to forget
Andy S
posted on 21/2/11 at 07:31 PM Reply With Quote
I think there is a 3 letter code stamped on the block on the exhaust side /bellbousing end that details the engine type.
Andrew
jacko
posted on 21/2/11 at 07:59 PM Reply With Quote
Thought the cosworth block was 205 and later ones 200
mcerd1
posted on 21/2/11 at 08:02 PM Reply With Quote
the engine code on the VIN number will tell you - otherwise you'll be taking the head off to check the pistons if you want to be sure
sorry but 205 is also a cossie block (no cossie ones were marked 202 as far as I know)
205's were used on 2wd cossies, sierra's and granada's (mostly with EFI) and the transits / P100's
I've got two high compression 205 blocks out of granada 2.0i's
and even the ford cossie manual says they cossie ones are 205 blocks picked from the standard production line
one of mine:
Pinto - 205 block
Pinto - 205 block
[Edited on 21/2/2011 by mcerd1]
sooty
posted on 27/2/11 at 08:18 PM Reply With Quote
Sorry jumping in here,
I have the same problem, I have a Transit block 205 where the code is NAT on the lug at the rear. But been told the engine was rebuilt, not knowing if its been modified to high compression or not.
Could it be seen if its high or low by doing a compression test and checking the pressure against the haynes book.
thanks
Dingz
posted on 1/3/11 at 09:36 PM Reply With Quote
Dave, according to my Haynes, the low comp engine is an NAE.
went on and on.
sooty
posted on 1/3/11 at 09:45 PM Reply With Quote
This link shows the Engine codes for High or Low compressions of all Pinto's.
http://en.wikipedia.org/wiki/Ford_Pinto_engine
The NAE is low comp for a P100 and NAT is Low comp for a Transit.
