New Topic New Reply
Author: Subject: Kits & Budgets
MikeFellows
posted on 22/2/11 at 09:36 AM Reply With Quote
Kits & Budgets
When I started building my car I had given myself a budget of £10k, with this figure approaching rapidly and the bits I still need to buy Im going to over shoot this by at least £2k and thats without booking the IVA etc..
Its the little things that are the killer, switches, cable, bonnet catches, header tanks, silicon hose, nuts and bolts (ive spent over £80 on nuts and bolts!) and other such bits
the big thing I didnt account for is the availabilty of information/parts (like not considering that you couldnt just buy an off the shelf busa manifold)
maybe I shouldnt have accounted for everything so well and played ignorant.
has anyone building there first car come anywhere near their budget?
Agriv8
posted on 22/2/11 at 09:56 AM Reply With Quote
its the bling bits that cost the money.
regards agriv8
posted on 22/2/11 at 10:01 AM Reply With Quote
I'd suggest 90% of builders go 30-40% over budget on their first build.
Like you say, it's the little things that mount up; paint cans, donor part refurb costs, tools and so on.
Also I found making/doing things twice after not being happy with the first attempt added more cost. e.g. I must have made half a dozen plywood dash blanks and covered at least 2 of them in vinyl before I was happy with it.
Then there's aesthetic things like I assumed I'd reuse the Sierra gearknob as it was perfectly OK. When I got close to finishing the car I couldn't stand the look of it in the cockpit and splurged £30 I didn't have on an OMP gear knob. It didn't change gear any better, but it certainly looked better
I'd love to build another to put in all the experience and knowledge gained on the first. I also now have or have access to pretty much any tool I'd need as wll which cuts costs and speeds thing up.
StevieB
posted on 22/2/11 at 10:04 AM Reply With Quote
I was a little over my budget on my Indy build - £8k budget and £8.5k spent before SVA costs.
I found the best way to save money was to keep things simple and basic where they can be easily upgraded at a later stage (I used copper central heating pipe rather than silicon hose, for instance). There are very few things on a kit that you can't easily upgrade over the course of a winter.
If I was to start another build I would keep everything as absolutely basic as possible to keep costs down and then upgarde as I go along.
posted on 22/2/11 at 10:10 AM Reply With Quote
Good point, I used micro bore copper plumbing for my fuel line after baulking at the price of fancy braided hose. Unlike the gearknob above it wasn't visible on the finished car anyway so never bothered me.
Bluemoon
posted on 22/2/11 at 10:22 AM Reply With Quote
Simple build single, donner, cost ~3.5K budget ~3K not bad... Could be cheaper.. It's a trade of time/skill and money and bling..
The figures do not include tools, and the kit was bought 2004, so was cheaper then.. Small things do add up, my solution was to find cheap fastening suppliers etc (yellow pages ect), kitcar ones are stupidly over priced.
Dan
Kwik
posted on 22/2/11 at 10:32 AM Reply With Quote
dpnt say that, my budgets only £1000 ...
Chaddy
posted on 22/2/11 at 10:34 AM Reply With Quote
I set myself a budget of £12k including IVA and registration, should come in under budget (just), as you say it is the consumables (nuts bolts, paint, clips etc) that add up but i put in a contingency figure to cover this. I had read so many builds where they had gone way over budget or given up due to lack of funds. I didn't want that to happen and this is the reason I hadn't built anything years ago as I never had the money, my brother built a Merlin years ago and didn't finish it properly due to lack of cash.
If I built another I could do it a good bit cheaper with the knowledge I have gained so far.
Chaddy
MK9R
mines only £250.......
[Edited on 22/2/11 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
adithorp
posted on 22/2/11 at 10:35 AM Reply With Quote
There was your mistake!
http://jpsc.org.uk/forum/
thunderace
posted on 22/2/11 at 11:18 AM Reply With Quote
then i got a dutton and put the other £9000 back in the bank lol
Richard Quinn
posted on 22/2/11 at 11:19 AM Reply With Quote
It was bloody P&P with me! No matter how hard I tried to work everything out, there were always more nuts/bolts etc needed. I think I must have spent as much on P&P as I did for nuts & bolts at Namrick.
I did find a cracking fasteners supplier not far from home but I work 45 miles away and they were only open when I was at work!
hughpinder
posted on 22/2/11 at 11:20 AM Reply With Quote
I gave myself a budget of 3k for mine. Originally I hoped that would include SVA/rd tax/insurance, but now I think I'll just get the car for that. The change from SVA to IVA will add to that, but I scavanged loads from the scrapyard (water header tank £1.00, as many rubber hoses/jubilees/clips/nuts and bolts as I wanted for £5.00 etc), as I'm not concerned about the underbonnet stuff for looks - so I have a mild steel inlet manifold (some scrap 6mm plate I had+3.48 for a 1m length of 45mm ms exhaust + a bit of paint ....), got CB1100 throttle bodies (42mm)+ injectors(335cc.min) for £35 etc. Alloy wheels with V rated tyres from scrappy £50. It probably helps that I have all the tools (including stuff like metalworking lathes) and can weld a bit.
My plan is to get it registered, then immediately spend out on proper wheels and tyres, then gradually fit the nice steering wheel/gear knobs/headers/trim/fancy lightweight brake calipers etc as and when I have the dosh.
Why not try putting a list of the bits you need in the 'wanted' section - I'm sure quite a few people have bought bits they haven't used, or know someone with something that might do instead...
Regards
Hugh
Irony
posted on 22/2/11 at 12:12 PM Reply With Quote
I have spent a considerable amount of time going over my budget for my build. I have been reasonable careful about keeping literally every invoice for all the parts I have bought and keeping a running total. I haven't bought poor quality but done research to get fair prices. My build is going to be over 10K and thats with a secondhand part finished kit. I have a seeking feeling that a lot of people on here 'forget' to add certain parts to their build cost. The odd bit here, the odd bit there. It adds up.
I respect those builders who have really taken the time to search scrapyards for cheap parts, but it's not always cheaper. By the time you have driven to the yard, ferreted out the bits, taken them off and cleaned them up and driven back. Depends on how much your time is worth.
On other forums people inflate their 0-60 times as people naturally do by a little bit. On here I think people naturally underestimate their build costs, it is locostbuilders afterall.
Irony
posted on 22/2/11 at 12:13 PM Reply With Quote
100% agree. I reckon at least 10% of my build cost is P&P.
StevieB
posted on 22/2/11 at 12:44 PM Reply With Quote
Ditto - it's a budget killer.
I got most of my fasteneres from my local auto jumble where there's a guy doing stainless fasteners of just about every type imaginable at decent prices, and also stalls selling bits of trim, fuel hose etc.
There was still a lot spent on p&p though.
I think the biggest thing that keeps a build within budget is having the experience of building a car previously, so you know what's truely needed and what isn't
I reckon there's £1000 or more of parts that I could have left till later (such as using the perfectly good sierra calipers I have instead of splashing out on a wilwood kit, and also refurbing the calipers myself instead of buying exchange items for the rear though there is good argument for this) or bits that were part of the original kit I bought from MK that I just wouldn't want to pay for again as I never used them (and IMHO are way overstated on their price list).
Biggest thing I learned was not to buy everything from one place for the convenience of it - I found that (in my experience) the kit manufacturers seem to buy stuff at the same price I could from another supplier then just add a mark up on top. Better to shop around and figure out where they get their supply form in the first place.
edsco
posted on 22/2/11 at 04:02 PM Reply With Quote
Hmmm....budgets budgets budgets!!
I set my myself a budget of £10k. This was loosely based on the fact 'build a kit from £7.5k' then add you VAT. However, £7.5K doesn't get you what you are wanting in terms of spec. I must be around the £11.5K mark at the moment and will have to spend the thick end of another grand getting it painted.
The plus side is, I must have spent about a grand tooling up for it etc so at least the next project i can knock that cost out.
I have also learnt a lot about suppliers and where is best to source items. A good fasteners and fixings and general race wear place is Trident Racing based at Silverstone. I must have saved a considerable sum going there for stuff.
One thing i have learnt (being a novice builder).....plan it all out to the n'th degree. I must have splashed a whole load of cash on silicone pipework which i later didn't require and kept Samco and other companies in business just off my purchases alone!! Maybe a slight exaggeration!!
edsco
pewe
posted on 22/2/11 at 04:16 PM Reply With Quote
If you are married/partnered there are two budgets you have to run:-
1) the "I've only spent..." one and 2) the "real" one.
First is for general publication and the second for your eyes only.
Be aware however that even the second one will not reflect the true cost of the build as you will lie to yourself e.g. tools bought are for general use not specific to the build and over-bought items are mainly "stock".
This probably doesn't help but I suspect reflects most builds.
Cheers, Pewe
ashg
posted on 22/2/11 at 04:52 PM Reply With Quote
i never really set a budget but 6k was the figure i kind of had in my head as an absolute max. i built the car for exactly £3080 not including iva and registration.
i kept every reciept in a folder and didnt add it up until the end.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
theduck
posted on 23/2/11 at 03:15 PM Reply With Quote
This is why I am buying a kit that will have everything I need in one box, so I know my £9k budget will mean a £9k build!
mr_pr
posted on 23/2/11 at 04:03 PM Reply With Quote
That is what I thought... Not the case.
Add tools, fasteners, shiny bits you decide you need, etc. You say you won't do it but you will!
My Build Progress
mr_pr
posted on 23/2/11 at 04:04 PM Reply With Quote
Totally agree with this. If I build again I will have the experience to buy all the little parts myself and save a small fortune!
My Build Progress
Doctor Derek Doctors
posted on 4/3/11 at 01:02 PM Reply With Quote
There's no point having a budget.... you only live once/can't take it with you.
A good way to save money is to work out what you will need and keep an eye open for deals on everything, I am not at the point of needing brakes or race wheels yet but I recently picked up a hardly used set of Sierra rear brakes and a set of nearly new Compomtive CXL's for £200 (for the whole lot), I don't need them yet but it has saved my around £200 on the build by picking them up now while they were cheap.
Always have a bit of cash handy in case you spot a good deal, you'll kick yourself if you miss a good deal and have to spend 2x the amount a month later.
New Topic New Reply
