Author: Subject: Has anyone swapped from live axle to IRS
tony.g
posted on 2/3/11 at 09:03 PM Reply With Quote
I am struggling to get my desired diff ratio in a live axle.
Has anyone done the swap to a Sierra back end.
What sortof job is it?
Tony
[Edited on 2/3/11 by tony.g]
meany
posted on 2/3/11 at 09:34 PM Reply With Quote
one idea may be for you to go a DE DION conversion.
possibly easier.
http://gtslocost.locostsites.co.uk/documents/pdf_files/RortyDeDionAxleAssembly.pdf
But if you definately want to go the IRS route, then i would personaly use the HAYNES ROADSTER as guide, most of the parts, if not all, are readily available.
[Edited on 2/3/11 by meany]
Antnicuk
posted on 2/3/11 at 09:44 PM Reply With Quote
what car are you talking about? i am considering it
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
tony.g
posted on 2/3/11 at 11:12 PM Reply With Quote
Thanks for the replies.
The De Dion looks interesting.
It's a Stuart Taylor Locoblade.
Tony
owelly
posted on 2/3/11 at 11:20 PM Reply With Quote
I'm swappin the Atlas rear end (four linked trailing arms and panhard rod) for the De-dion with a Watts linkage. I'm hoping to make a subframe that will pick up on the trailing arm points on the chassis but my car isn't normal!
This is as far as I've got so far!!
More piccies here...
http://s56.photobucket.com/albums/g185/moshty/LSRalfa/de-dion/
[Edited on 2/3/11 by owelly]
http://www.ppcmag.co.uk
snapper
posted on 3/3/11 at 06:43 AM Reply With Quote
GavinC did this conversion at the build stage using DeDion, the main difference is the Sierra axle is longer widening the rear track.
The trailing links brackets are therefore further inboard on the DeDion if using a book chassis compared with the wider chassis used with an IRS setup.
I eat to survive
I drink to forget
Richard Quinn
posted on 3/3/11 at 07:52 AM Reply With Quote
The IRS version of the Aries uses shortened drive shafts to maintain rear track. I can't see why a shorter DeDion couldn't be done using shorter driveshafts
MK9R
posted on 3/3/11 at 08:26 AM Reply With Quote
possibly easier.
Is this a design to replace the escort axel, leaving all pick ups and arms untouched? I have live axel fury and wondering is this could give me anything??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
gavin174
posted on 3/3/11 at 08:35 AM Reply With Quote
I decided to chance my chassis from live axle to de-deon.
I originally fitted an escort width de-deon with standard front wishbones
Was struggling to find someone to shorten the driveshafts so then had another de-deon made
This was sierra width, but kept escort width at the front end.
I the decided to change the front end for sierra width.
All this before the car was IVA'd.
tony.g
posted on 3/3/11 at 10:53 PM Reply With Quote
I would like a De dion axle but i am not much of a welder.
Is it possible to buy one already made?
beaver34
posted on 4/3/11 at 05:21 PM Reply With Quote
will they take more power than a escort english?
posted on 4/3/11 at 05:32 PM Reply With Quote
What's the weak point in the Escort axle? Half-shafts?
It's Evolution Baby!
meany
posted on 5/3/11 at 11:12 PM Reply With Quote
possibly easier.
i assume its a rorty design for an alternative to whatever the Ron Champion Locost uses...other than that..no idea.
