posted on 6/3/11 at 04:00 PM |
Argghh! Fuel pipe! AGAIN!
Wandering towards the shower this morning, I was greeted by a frantic shout from the missus downstairs - "There's an awful stink of petrol
in the garage".
Went outside (after dressing!) to see a steady drip, drip, drip of fuel from under the car. This meant that I had to undo and remove the boot box,
check where the leak was (it was the bit of flexible hose that joins the tank to the hard fuel pipe) then drain the tank. As I had well over half a
tank and only two 5-litre petrol cans I had to go out for a long drive to 'waste' a fair bit (which was actually a nice drive... ).
Now I have to find some fuel hose that will resist modern unleaded fuel without decaying...
This it the third time this has happened to me - am I the only one who has this problem?
MakeEverything
posted on 6/3/11 at 04:02 PM |
As I had well over half a tank and only two 5-litre petrol cans I had to go out for a long drive to 'waste' a fair bit (which was
Us Motorcyclists Love motorists like you!!
[Edited on 6-3-11 by MakeEverything]
Kindest Regards,
Richard.
posted on 6/3/11 at 04:15 PM |
Don't worry - I wasn't losing very much - it would have been one tiny drip every 100 yards. It probably evaporated in the breeze before
it got to the road!
I wouldn't have gone out if it had been more than that.
posted on 6/3/11 at 05:19 PM |
Been doing some research - this was interesting and very relevant...
VolksBolts
r1_pete
posted on 6/3/11 at 05:21 PM |
If you're talking small bore, 6 - 8 mm, I've found the hight pressure injection hose best, FI & unleaded became commonplace about the
same time, so it seems properly compatible. 4 x the price but does last.
austin man
posted on 6/3/11 at 05:37 PM |
Always best to use high pressure IMHO, the braided stuff you can get appears to go soft I haven't heard a good think about the stuff. I used 8mm
copper pipe with the smallest pieces of rubber I could to connect to tank and carbs
RazMan
posted on 6/3/11 at 05:48 PM |
I used the braided Nitrile lined stuff which seems to last well (5 years so far) but did recently notice a bit of a leak due to overtightening the
Mikalor clamps so I changed them to Mikalor Spring Clips and all is ok again.
Raz
posted on 6/3/11 at 06:02 PM |
It looks like SAE J30R9 is the grade I need to find...
907
posted on 6/3/11 at 06:13 PM |
To the best of my knowledge Raz is indeed correct.
Nitrile is the fuel proof rubber used. However, nitrile decays with UV light so fuel
pipe is made with an inner layer of nitrile, then a reinforcing braid, then a layer
of different rubber on the outside. Stainless braid may then be used over the top.
In tank hoses need to be nitrile / braid / nitrile.
err, possibly.
Paul G
posted on 6/3/11 at 06:32 PM |
Apparently SAE J30R9 hose has a fluorestomer lining - whatever that is...
norfolkluego
posted on 6/3/11 at 06:47 PM |
in the garage".
You let your wife in the garage, the inner sanctum of blokeness, where chaps wear their overalls with pride, where we have our own language and
culture
We're doomed, doomed I'm telling you, we'll be wiped out like those tribes in the Amazon now they've found us.
PS never had your problems probably beacause we're always tinkering with it and changing stuff.
[Edited on 6/3/11 by norfolkluego]
flak monkey
posted on 6/3/11 at 08:11 PM |
I used Codan Fuel hose in mine. Available from various motorfactors off the reel. Never had a problem with it
Sera
http://www.motosera.com
RazMan
posted on 6/3/11 at 08:23 PM |
That's the stuff - really flexible but capable of running at 12 bar IIRC
Raz
posted on 6/3/11 at 10:21 PM |
culture
I allow her one small corner for the tumble dryer and freezer...
Never heard of Codan - will have to do some searching.
UPDATE: just searched for Codan, and they declare their stuff to be SAE J30R7 - almost as good as R9, according to some sites.
UPDATE 2: ThinkAuto's catalogue shows J30R9 in 8mm - I plan to give them a call in the morning.
[Edited on 6/3/11 by David Jenkins]
paulf
posted on 7/3/11 at 06:05 PM |
I think Codan was one of the manufacturers that had a problem when unleaded was first introduced.I had some that perished in a couple of places and
have replaced it all since the car has been on the road.I also had a Citroen that suddenly sprang a leak under the tank and that had nearly completely
disintegrated, i bought some new fuel pipe for that and it was colored green as suitable for unleaded but never seen any green fuel pipe since.
Paul
posted on 7/3/11 at 07:07 PM |
I saw a interwebby link that said that Codan Rubber had gone bust...
LINKY
Any road up, I've ordered 2 metres of Think Auto's finest 30R9, which is 25 times less permeable to alcohol (ethanol, etc) than 30R6,
which is what Halfords sell (I looked today). It's also 6 times less permeable than the commonly available marine-grade hose (ISO7840A1) - but
not as fire-resistant as the marine stuff.
I also went around some auto supply places today - it's disgraceful what they're flogging as fuel pipe. If their stuff was marked at all
(many weren't) it was the old BS standard, which is even older than 30R6. It might have been suitable in the 1980s & 1990s, but as much use
as a chocolate teapot for modern petrol that contains a percentage of ethanol & other manufactured bio-fuels. IMHO, of course!
posted on 7/3/11 at 08:00 PM |
injection hose or buy some polyflex pipe and fittings from an LPG supplier.
posted on 7/3/11 at 10:12 PM |
All of the hose I've looked at is injection hose - most being sold generally is either of very old spec, or completely unlabelled.
I can't comment on polyflex pipe as I've not seen it, but as LPG doesn't contain any form of alcohol I'd be very wary about
it.
Danozeman
posted on 7/3/11 at 10:28 PM |
Iv got high pressure fuel injection hose on mine. Never had a problem touch wood.
Dan
paulf
posted on 7/3/11 at 10:43 PM |
Mine has injection hose and copper pipe on the high pressure side but the fuel return to the swirl pot through the tunnel is nylon pipe.The nylon
would do for all the system apart from the difficulty in making high pressure joints.I fitted it as it was a temporary measure until i could fit a
copper return line through the tunnel when converting to injection but it has been there ever since.
Paul
