daniel mason
posted on 18/3/11 at 08:38 PM |
fuel roll over valves ?
am i right in thinking that a standard one way valve ( letting air into the tank,but stopping anything from going out of the tank) will fail iva? i
have heard of people passing with them and people failing with them. if they are not ok how do you mount a genuine roll over valve (like the ones in
merlin) when they have a threaded union to connect to tank? as the tank has no threaded outlet and valve needs to be verticle!
can you use a small piece of hose from tank to valve and mount the valve vertically onto a chassis member, using a hose clamp to connect the hoes to
the threaded end of valve? or are special unions available? what are your thoughts on this subject? cheers
zetec
posted on 18/3/11 at 09:39 PM |
I used one from a trials bike, small plastic one with push fittings both ends, couple of quid from local offroad bike shop.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
daniel mason
posted on 18/3/11 at 09:44 PM |
are they a proper rollover valve or are they a 1 way valve?
adithorp
posted on 18/3/11 at 09:48 PM |
You need this one. Two way valve lets gas in and out
but not fuel out.
http://jpsc.org.uk/forum/
daniel mason
posted on 18/3/11 at 10:31 PM |
but thats almost £10 more than the one with 1/4" - threaded end. this is what i didnd understand? whats the diference?
mark chandler
posted on 18/3/11 at 10:42 PM |
You need something that fuel vapour does not rot, just nip one out of an old brake servo
Madinventions
posted on 18/3/11 at 10:57 PM |
I used the one that is fitted to the top of the tank in a Ford Fiesta (you can get at it from under the rear seats). In the photo, it's the
round white bit at the bottom right of the tank with the stub of fuel pipe coming from it. Cost nothing from a scrapyard, and designed for the job.
2 way breather with rollover cut-off.
The little white cap at the end of the hose is a silencer designed for pneumatic systems. It lets air in and out, but really helps to cut down any
fuel smells.
HTH,
Ed.
[Edited on 18/3/11 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
macc man
posted on 18/3/11 at 10:58 PM |
Not sure if iva proof but I used the standard sierra item. has a ball inside to cut off fuel in a roll over.
Madinventions
posted on 18/3/11 at 11:02 PM |
Should be IVA proof if they're type approved?
daniel mason
the ones i saw at merlin were twin ball item,but had to be mounted vertical!
Dave Bailey
posted on 19/3/11 at 09:25 PM |
Hi.... I have a vent for my tank built into my filler... I had a quick look in the IVA manual but couldn't see anything about having to fit a
roll over valve to cut the fuel or anything... Are there specific requirements?
Dave B
