Author: Subject: Rear Diffuser Fitted
spdpug98
posted on 19/3/11 at 03:31 PM Reply With Quote
After having my diffuser sitting in the garage since the Autosport Show, I finally decided to get my butt into gear and get it fitted (I’m sure the sunny weather influenced my decision!)
My Blog: http://spdpug98.wordpress.com/
chicade
posted on 19/3/11 at 03:35 PM Reply With Quote
i like that where is it from?
bi22le
posted on 19/3/11 at 03:39 PM Reply With Quote
I need one of them in my life!!
Where from and how much please.
Biz
Please read my ring story:
spdpug98
posted on 19/3/11 at 03:44 PM Reply With Quote
It is from MNR, if I remember correctly it was £175 but will check
ETA: Yes it was £175 inc VAT
[Edited on 19/3/11 by spdpug98]
bi22le
posted on 19/3/11 at 04:58 PM Reply With Quote
That would be why it fits your car perfectly!!
How has it been fixed on?
spdpug98
posted on 19/3/11 at 05:15 PM Reply With Quote
It is fixed with a metal strip along the front leading edge (riveted to the floor) and I have secured the rear in the wheel arch with 1 bolt through the side panel....hopefully that makes sense
johny p
posted on 19/3/11 at 06:57 PM Reply With Quote
that looks very nice mate... might spend some brass and treat myself...
loggyboy
posted on 19/3/11 at 07:44 PM Reply With Quote
How far under does it go? is the rest of the undeside nice and smooth?
spdpug98
posted on 19/3/11 at 08:11 PM Reply With Quote
It starts at the end of the floor through to the back of the car, the whole floor is now flat (exc engine bay area)
I doubt it will actually make any differance to the car but I really like it
Wells
posted on 20/3/11 at 09:16 PM Reply With Quote
Looks great! I have one in the garage also. Could you post some pics of how you fixed it to the car? Thanks in advance.
spdpug98
posted on 20/3/11 at 09:28 PM Reply With Quote
Not sure if you can see from the picture, I have drilled and bolted the rear lip through the bodywork and you can just about see the strip of ali on the front leading edge that I have riveted through the floor - it all seems secure and solid but may put another fixing through the body
Wells
posted on 21/3/11 at 12:12 PM Reply With Quote
Thats great. Thanks for doing that. I might change the alloy strip for a couple of hinges so removing the side bolts will allow the diffuser to drop incase access is needed to the diff etc.
spdpug98
posted on 21/3/11 at 03:46 PM Reply With Quote
Good idea - maybe a mod for me in the future too
GeorgeM
posted on 21/3/11 at 05:10 PM Reply With Quote
Hi, fitted mine at the weekend (at last).
rivetted the ali strip to the floorpan, then the diffuser slips into
the gap between the ali strip & floorpan. Diffuser held up at the
back by 4 bolts through the diffuser into rivnuts in the bottom lip
of the back panel. Just remove the bolts to remove it.
Mine is also higher up, as it it fitted around the back panel
rather than under it.
Will try to remember to take pics......
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
