Author: Subject: Drilling windscreen surround to fit Weather gear.
stevegough
posted on 21/3/11 at 07:55 PM Reply With Quote
Something that has had me worried when it comes to fitting a roof - drilling and fitting poppers to the thin windscreen surround.
The ally channel on the screen is 16mm x 16mm and the glass sits quite well into it, so the solution I adopted was to get some stainless 3.5mm screws, grind the tip off...
Then screwed into a carefully-drilled 3mm hole, the screw tip finishes in the rubber seating....
Then, repeat with the actual screen itself - pretty successfully!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Daddylonglegs
posted on 21/3/11 at 08:03 PM Reply With Quote
Nice job mate
Very useful thread, could save a lot of cracked windscreens. Don't work for Autoscreens do you
Just realised what I said then. if you did work for them then the last thing you want to do is avoid cracked screens! lol!
[Edited on 21/3/11 by Daddylonglegs]
stevegough
posted on 21/3/11 at 08:04 PM Reply With Quote
The story continues...
I am now working on getting the Weather - Gear I have bought from GBS (for a zero) to fit accurately - I've found it to be about an inch too big where it drapes over the rear bodywork, so I am fitting a slight modification to the poles to take up the excess. This will also be a double - whammy - it'll adjust for slackness in the roof when hot weather hits!
Framework before modifying...
After fitting 9" lengths of M12 threaded bar with nyloc nuts to adjust the length...
Watch this space, because that's as far as I've got up to now.......
Luego Locost C20XE.
rallyingden
posted on 21/3/11 at 10:50 PM Reply With Quote
Nice one Steve. I'm hoping that will be my summer job
RD
mad4x4
posted on 22/3/11 at 02:53 AM Reply With Quote
You got any dimension of the width of the windscreen of the "Body Bars"- would this fit an MK?
I made my own screen so
Scot's do it better in Kilts.
stevegough
posted on 22/3/11 at 09:21 AM Reply With Quote
I can measure whatever you need - screen? ally support bar width / height ? Let me know.
Luego Locost C20XE.
