Author: Subject: Sabelt harness bolt size
goodguydrew
posted on 25/3/11 at 10:13 PM Reply With Quote
My seat belts have 15mm mounting holes. I expected 7/16. Am i expected to use 15mm bolts, or are smaller bolts acceptable?
[Edited on 25/3/11 by goodguydrew]
daniel mason
posted on 25/3/11 at 10:18 PM Reply With Quote
surely a smaller bolt wont take the 15mm thread?
flibble
posted on 25/3/11 at 10:20 PM Reply With Quote
Mine had big holes but also a stepped collar that fitted into them and the 7/16 bolt went through that.
The collar is so the bolt can be done up tight but the anchor can still spin around.
[Edited on 25-3-11 by flibble]
Macbeast
posted on 25/3/11 at 10:21 PM Reply With Quote
My Sabelts, which coincidentally I fitted today, are 7/16
Daddylonglegs
posted on 25/3/11 at 10:22 PM Reply With Quote
I think you'll find that the hole is to take the 'top hat' style washer/spacer which has a 7/16" hole for the bolt. The idea of them is, as far as I can tell, to allow the plate to rotate a little even when the bolt is fully tightened to allow the belt to sit correctly.
JB
goodguydrew
posted on 25/3/11 at 10:36 PM Reply With Quote
Ahh, I see. Thanks.
Does anyone know of a source for these adaptor bushes?
Or a picture of one?
Or spares ones?
wicket
posted on 26/3/11 at 08:39 AM Reply With Quote
From my experience they usually come with the belts.
