posted on 26/3/11 at 02:42 PM |
FS: XE Engine, Carbs, Gearbox, Wheels / Tyres, Stack Dash, Etc...
I think I might be starting to build a reputation for this kind of post... maybe not!
FOR SALE DUE TO (ANOTHER) CHANGE OF PLANS!
ENGINE
Early Block (No Cat Required).
GM Head With 'Porous-Fix'.
Kent Vernier Pulleys.
QED 420 Camshafts.
Ali Shortened Sump.
Starter Motor.
New Oil Pump, Water Pump, Lightweight Ali Crank Pulley, Cam-Belt and Idlers.
Very Clean... Block Freshly Painted Black, Cam Cover Powder Coated Met Red, Met Silver Spark Plug Cover.
Cam-Cover Flange Has Been Machined Off (Running Without Belt Covers).
Power Expected to Be Around 200-210bhp.
£850
CLUTCH FLYWHEEL
Custom Ali Lightweight Flywheel.
Alcon 5.5" Twin-Plate Clutch.
£450
INDUCTION / IGNITION
MBE 912 ECU, Loom, Dizzy and Leads.
Ali Inlet Manifold.
Weber 45 Carburetors, Linkages and Trumpets.
£550
GEARBOX
Ali Bellhousing NOT included!
Type 9 With Tran-X Clubman Internals (Close Ratio / Straight Cut).
Ratio's unknown - was used for hill-climbing in a car with a 4.4 live axle.
Quick Shifter Kit (presently on backwards in the photo ).
£450
EXHAUST
4-2-1 With Silencer Made by Tony Law.
£250
VX 2.0XE ENGINE MOUNTS
£10
VX 2.0XE ENGINE COVER
£10
ULTRALITE WHEELS & YOKO A048R's
Two 13" Ultralite wheels. BRAND NEW - NEVER FITTED.
6" wide.
Grey with polished lip.
Mini fitment (101.6 PCD and ET10)
Both fitted with 185 section tyres that have only done a few hundred miles.
£150. Would cost a tenner to post them.
STACK ST8102SP, LOOM, SWITCHES & SPEED SENSOR
Switches and speed sensor are brand new. The rest is used, but in VGC.
£400
CARBON FIBRE HEAD RESTRAINT
In VGC. These are stupidly expensive when new!
£25
I'd consider a 2004-2006 R1 Package or an Aprilia RSV-R Factory Package in PX against any of the above.
Thanks (again!) for looking!
Some pics... (Engine is not at the house, so will get some more later).
[Edited on 28/3/11 by scootz]
It's Evolution Baby!
andylancaster3000
posted on 26/3/11 at 04:19 PM |
u2u sent!
daniel mason
posted on 26/3/11 at 04:32 PM |
if your thinking of going s2000 route like you were a while back, i may hve some interesting bits for you!
posted on 26/3/11 at 05:09 PM |
Thanks for the offer Daniel, but it's a complete change of plans... again!
posted on 26/3/11 at 05:11 PM |
My SP1 engine and clocks are also still for sale if anyone is interested... will sell both to a LCB'er for £350! Muchos barganos!
franky
posted on 27/3/11 at 09:28 PM |
U2U about the dash.
posted on 28/3/11 at 02:10 PM |
Replied.
zilspeed
posted on 28/3/11 at 04:14 PM |
The engine installation you're selling there is a pretty snorty setup.
Pray tell, what the f**k are you going to fit that is an improvement ?
It's already a magnificent setup.
You don't actually need any more.
Apologies if I grabbed the wrong end of the wrong stick again.
posted on 28/3/11 at 04:21 PM |
Nope... you have the right end of the right stick!
I really want to crack on with the trike project, and I also have a single-seater in the garage for playing with that's nearly good-to-go, so
I'm jumping ship and trying to cash in some chips for funding them both!
posted on 28/3/11 at 04:24 PM |
Oh, and it was all available for the paltry sum of £2250... right up until Ben Copeland bought the bellhousing!
I'd do what's left of the XE related parts for £2k... sweetie-money for that spec of drivetrain!
posted on 29/3/11 at 01:26 PM |
The Stack unit is an early model, so price reduced to £350!
posted on 29/3/11 at 06:53 PM |
HEAD RESTRAINT SOLD
posted on 30/3/11 at 11:33 AM |
GEARBOX & BIKE ENGINE SOLD
posted on 30/3/11 at 08:51 PM |
STACK UNIT SOLD
posted on 31/3/11 at 11:46 AM |
EXHAUST SOLD
posted on 5/4/11 at 01:05 PM |
CARBS & ECU SOLD
Just the XE engine, clutch / flywheel, mounts and front cover left.
Will do the engine and clutch / flywheel for £1150.
speedstar
posted on 5/4/11 at 02:04 PM |
Are the wheels still there? Might be perfect!
Edit: Need four. Nevermind
[Edited on 5/4/11 by speedstar]
franky
posted on 5/4/11 at 03:31 PM |
your dash has made it to ebay!
posted on 5/4/11 at 05:20 PM |
So it has!
He didn't check the RPM limit... doh!
Ben_Copeland
posted on 5/4/11 at 05:30 PM |
Engine mounts!!! I didn't see them! What car did they come out of mate? Narrow or wide?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 5/4/11 at 05:58 PM |
They came out of a Procomp LAGold... I think that would be narrow in comparison to other Sevens, but you'd best drop Procomp a U2U to be
sure.
