Author: Subject: Type 9 Gearlever Turret Extension
richardlee237
posted on 26/3/11 at 06:19 PM Reply With Quote
I have bought a 2nd hand type 9 extension of the rally design type, unfortunately with no fitting instructions.
To locate the new fork on the gear change control rod I presume you have to remove the plastic sleeve that fits over the control rod. Does this lever out or do you have to cut it off ?
Is it necessary to make the pressed steel cover which is in the back of the gearbox, a close fit on the new shaft or just enough to keep the road dirt out.
Richard
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
tomgregory2000
posted on 26/3/11 at 06:28 PM Reply With Quote
The little plastic bit should lift out with a bit of force.
I never bothered with the rear plate after i had removed it.
richardlee237
posted on 26/3/11 at 06:32 PM Reply With Quote
Info much appreciated, just didn't want to make a Barrichello of it.
Quote Lord Kelvin
Quote Richard Lee
"and cars"
Rocket_Rabbit
posted on 23/5/11 at 10:15 PM Reply With Quote
I have one of these that is playing up on my box so I am going to get a brand new one. Can you fit without removing the box?
