<<  1    2  >>
New Topic New Reply
Author: Subject: Venting my anger.....
Krismc
posted on 26/3/11 at 07:39 PM Reply With Quote
When i vent my anger into my loud pedal, my engine gets very hot and and i need a vent at back of bonnet too let off some steam, can some one think off a good shape? here is the bonnet, i cant photoshop for the life of me, was going to put a long vent at back off bonnet but ive got 2 humps there...
Krismc
posted on 26/3/11 at 07:40 PM Reply With Quote
Oh and before you ask, ive opened up the vent at the front so the cold air rushes over the top of engine.
daniel mason
posted on 26/3/11 at 07:46 PM Reply With Quote
carbonmods NACA duct on backwards?
bi22le
posted on 26/3/11 at 07:48 PM Reply With Quote
I think there are loads of options on shape, finish and position.
It think its really up to you and what look you like.
Please read my ring story:
MakeEverything
Why not solve the problem of overheating?
Kindest Regards,
Richard.
posted on 26/3/11 at 07:50 PM Reply With Quote
Kris, is your engine plumbing correct? or, is the same as when it last burned you?
I suspect you haven't corrected the bypass pipe yet?
posted on 26/3/11 at 07:54 PM Reply With Quote
A couple of side vents would do the job efficiently rather than one on top. The bonnet scoop is more of an ornament than anything, most of the air under your bonnet is coming in through the radiator grille and going out under the floor or down the transmission tunnel.
Krismc
posted on 26/3/11 at 07:57 PM Reply With Quote
As you can see, ive changed all the plumbing, blocked off the bypass, removed the stat, added in a pipe for overflow, ran waterpump other way(correct way)
Its not very hot, but it climbs a little sitting in traffic the heat has no where too go - normal running 95-105, traffic 100-115
Something like this......
but in silver mesh
[Edited on 26/3/11 by Krismc]
Ninehigh
posted on 26/3/11 at 08:04 PM Reply With Quote
I'd suggest side ones too, another top one would just mean the air would pass over the top where if you put the exit vents low on the sides it has to move that way.
Krismc
posted on 26/3/11 at 08:07 PM Reply With Quote
Surely, plenty of air coming in via rad would force enough air up over, dont want to weaken bonnet too much, althought i could just add a 50mm round hole too either side.
Macbeast
posted on 26/3/11 at 08:08 PM Reply With Quote
I would guess that vent on the top of the bonnet is too small to do anything except make a whistling noise
posted on 26/3/11 at 08:27 PM Reply With Quote
You need to plumb the bypass into the bottom hose, away from the headtank, put the stat back in with a 5mm hole drilled in it.
Get shot of the raceline (they are rubbish!) and put the oem themo bit back on.
And, where is the bleeding pipes?? You have it plumbed up wrong mate!
SPYDER
posted on 26/3/11 at 08:34 PM Reply With Quote
Is the radiator fully ducted inside the nosecone?
ie. does all the air that goes into the nose have to go through the rad?
A duct in the top of the nosecone might let more heat out than a bonnet duct.
Is the rise in temp being kept in check by the fan or is it actually getting near to boiling over?
Have you considered wrapping the exhaust to reduce the underbonnet temp?
Geoff
Krismc
posted on 26/3/11 at 08:42 PM Reply With Quote
Ive also been told not too use the side connection on the raceline waterail, due too the temp differance.
you will have to Show me a diagram off what you mean
Krismc
posted on 26/3/11 at 09:04 PM Reply With Quote
...here is how its plumbed.
Humbug
posted on 26/3/11 at 10:20 PM Reply With Quote
I've got vents at the rear of the sides of the bonnet as well as a scoop/inlet vent similar to yours (needed to clear the engine) and have no problem with engine temp. Having vents in the sides, rather than on top of the bonnet, has the added advantage of not spraying you in the face with boiling coolant if a hose comes off (guess how I found out?)
paulf
posted on 26/3/11 at 10:27 PM Reply With Quote
Refit the original thermo housing and add a bleed pipe from air bleed on housing to the header tank, also take a hose from the heater outlet on exhaust side of housing and connect to the water pump near the connection with the bottom hose where you have one from the header tank at present.
Mine is plumbed like this and always runs at a nice steady 85 to 90 deg , I have also heard lots of people have problems with the raceline set up.
Paul
Steve Hignett
posted on 26/3/11 at 11:53 PM Reply With Quote
Some pics here:
http://www.locostbuilders.co.uk/viewthread.php?fid=4&tid=115155
Krismc
posted on 27/3/11 at 09:22 AM Reply With Quote
the only reason ive got a front scoop is the engine height, had to cut a letter box to make it fit, yea ill try a side exit vent first, dont want to spoil the look of the car and the battery and ecu is up there, so rain and washing the car would funnel the water on all the electrics.
Krismc
posted on 27/3/11 at 09:27 AM Reply With Quote
Originally posted by Steve Hignett
Some pics here:
Like the vortx ones, except i might do them alternative sizes, ill quickly mock up a pic if anyone can give opinions.
Krismc
posted on 27/3/11 at 09:31 AM Reply With Quote
I like these.......................
so how about thism but only on my exhaust side for now, see if the heat is lower........................
or even
[Edited on 27/3/11 by Krismc]
neilj37
posted on 27/3/11 at 10:12 AM Reply With Quote
Kris,
Check out the pics of my old MNR in my photo archive. Had a similar problem to you but nose vent helped to reduce the temperatures. The radiator fan was also on a manual switch so when you were sitting in traffic you could put the fan on to keep temps down.
scutter
posted on 27/3/11 at 10:40 AM Reply With Quote
I would suggest side vents rather than top. If/when the rad hose pops off, you won't get how anti-freeze all over your helmet Guess how i found out.
ATB Dan.
Krismc
posted on 27/3/11 at 03:51 PM Reply With Quote
Here is what i managed today, saying as my dremel isnt playing ive had too do it the old school way, while sitting on front lawn with all passers by watching. well it was such a nice day.
I decided too go with slots, so i drilled 4 holes, cut between them and filed and sanded by hand until i achieved a decent result, i dont have much silaflex so i just did the exhaust side for now, looks alright i think.
Fred W B
posted on 27/3/11 at 04:35 PM Reply With Quote
Nice work!
What would look really cool is if you cut two pieces of 3 mm hardboard, one the same shape as the cut outs but just a bit smaller, and the other with the same shape/size hole as the bonnet holes cut into it. Then put your piece of (ally, I presume) mesh between them on a firm surface and press/hammer the smaller piece down until it is flush with the other, which will give you a joggled edge on the mesh, and let the mesh sit flush with the outside face of the bonnet.
You might have to experiment a bit with the clearances between the wood bits to get a nice result.
Fred W B
[Edited on 27/3/11 by Fred W B]
<<  1    2  >>
New Topic New Reply
