Author: Subject: where to buy a kit car loom?
daniel mason
posted on 28/3/11 at 08:17 PM Reply With Quote
is there anywhere i can get a loom for my mnr? just to control lighting,fan,horn,handbrake and brake pressure etc. engine loom is in and seperate to car loom.
wylliezx9r
posted on 28/3/11 at 08:26 PM Reply With Quote
I got mine from premier looms, he will make it to your spec, I havnt fitted it yet but it looks top quality and came with full instructions, it even came with its own crimpers.
George Best
T66
posted on 28/3/11 at 08:28 PM Reply With Quote
While I havent yet bought from premier looms, I rang them recently and found them to be very helpful.
Can make anything to your spec
big-vee-twin
Just finished installing my Premier loom, no problems high quality
I think SVC make a basic loom too called uni loom
http://www.triangleltd.com
adrianreeve
posted on 28/3/11 at 08:37 PM Reply With Quote
Another vote for the premier loom!
fluidslvr
posted on 28/3/11 at 08:52 PM Reply With Quote
give eddie99 a shout on here..
quality loom with instructions..recommended
http://mkmidi.blogspot.com
embraboy
posted on 28/3/11 at 09:00 PM Reply With Quote
Another vote for Premier Wiring. Alan is really helpful. Loom can be customised to what you need and comes with clear instructions.
http://www.premierwiring.co.uk/
simonwinn
posted on 28/3/11 at 09:01 PM Reply With Quote
Another one for premier, Alan is very helpful.
AndyW
posted on 28/3/11 at 09:10 PM Reply With Quote
Another for premier, Alan is a good bloke, really helpful and will built it to do as little or as much as you want.
GeorgeM
posted on 28/3/11 at 09:15 PM Reply With Quote
why not get the proper one from MNR ?
it will fit properly then.
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
daniel mason
posted on 28/3/11 at 09:33 PM Reply With Quote
didnt even know mnr did them?
snowy2
posted on 1/4/11 at 07:37 AM Reply With Quote
wiring does not require the sacrifice of any chickens or anything, it is very easy to wire up a kit car, Here is a link to an article i wrote some years ago and is posted somewhere on a locost forum,
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
it does cover the subject your asking about. and here is a link to something about using relays (for fitting cooling fans)
http://www.godspeed.me/forums/viewtopic.php?f=14&t=1289
ceebmoj
posted on 15/11/11 at 10:57 AM Reply With Quote
Does any one have pictures of a loom from
MikeFellows
posted on 15/11/11 at 12:12 PM Reply With Quote
i tried contacting premier for over a month, no reply to emails and one mobile dead, one to voicemail.
i gave up 2 weeks ago and someone linked me to eddie99 on here, its due in the post today or tomorrow
edit to add that they have updated their site in the last 2 weeks now so who knows
[Edited on 15/11/11 by MikeFellows]
snowy2
posted on 16/11/11 at 05:49 PM Reply With Quote
I have posted various links to full instructions on wiring cars. if you were able to build your car why wimp out on the electics? wiring a kit car is a doddle, give it a go you'll surprise your self.
sometimes you are the pigeon, most of the time the statue.
RK
posted on 17/11/11 at 01:25 AM Reply With Quote
Snowy2 has provided EXCELLENT advice in his articles. I have done my car 4 times now (and my car has not yet been on the road), and had I seen his information, I would only have had to do it once. I have made a bodge of it every time, but at the moment, it works. Next year, I'll take it apart and do it properly. I had trouble figuring out where to put the fuses, junction boxes (of which I have many) and relays. I just couldn't visualise things.
It is not easy, however, and is very very hard on your back. Also, my crimping is terrible, much worse than my soldering. Many earths have come loose, which has been very frustrating. I wish I had someone to do it all for me, but I don't so I have to just carry on as usual. I do feel it is misleading to tell people that it is a doddle, when it clearly is not; last go took me 6 months of solid, continuous work. It can be a rat's nest of wire under your dash if you "just do one wire at a time". No, you need to know what you are doing, or risk blowing a lot of fuses or worse, cause a fire.
