Author: Subject: ECU and fluctuating idle
antwan
posted on 2/4/11 at 06:45 PM Reply With Quote
Hi all,
I started my car for the first time today. Things went great. The car is an MNR vortex BMW 318is powered.
I let it run upto temp, fan kicked in... all good.
I then gave it a few beans (as ya do) and when it returned to idle, it started pacing between about 800 rpm normal and 1500 rpm, cycling every couple of seconds. What the hell was it doing??
I have heard stories of ECUs struggling if powered down for long periods of time but cant find anything on t'interweb. I had a head gasket go on an old 320i E30 and after three weeks or so of tinkering, the ECU didnt have a clue and kept stalling.
Any ideas or experiences?? Do I have to follow a certain start up procedure?
(and on another topic, sorry, but how do I copy a pic into this message) thanks!
Dingz
posted on 2/4/11 at 07:06 PM Reply With Quote
Does this engine have an idle control valve? (it leaks air past the main butterfy) If so they can stick, the usual cure is to take it off, spray some carb cleaner or similar in, move the actuator back and fore a few times and then reassemble.
went on and on.
flak monkey
posted on 2/4/11 at 07:10 PM Reply With Quote
Idle valve stuck or an air leak.
Sera
http://www.motosera.com
perksy
posted on 2/4/11 at 07:15 PM Reply With Quote
Air leak on inlet maifold or idle control valve ?
norfolkluego
posted on 2/4/11 at 07:26 PM Reply With Quote
+ 1 to that, once had a Ka as a daily driver, had exactly that problem, was the idle control valve
avagolen
posted on 2/4/11 at 08:38 PM Reply With Quote
I had a similar problem on a Honda once - it was caused by the o2 sensor not responding fast enough.
When cold, the ECU was using open loop and it was fine.
Once the engine was warmed up, the O2 sensor was being used. it was sluggish and caused an annoying hunt.
About 500 rpm if I remember correctly.
Replaced the sensor and back to normal.
(that was after honda said it was the idle control valve sticking and they cleaned it.
Said it could not be the o2 sensor as there were no fault codes !!!).
Len
[Edited on 2/4/11 by avagolen]
