Author: Subject: Removing internal circlip, without holes?
ReMan
posted on 3/4/11 at 06:49 PM Reply With Quote
Got a kit of seals to rebuild thge Saab master cylinder.
Unfortunatly the main circlip that holds the lot together is blind and has no holes for circlip pliers
Any tips on how to prize it out before I get really cross or lose an eye?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
hearbear
posted on 3/4/11 at 06:54 PM Reply With Quote
There is usually a small machined section on one end that you can get an eletrical screwdriver in to prise it out of the groove
Daddylonglegs
posted on 3/4/11 at 07:00 PM Reply With Quote
Yep, normally a nick in the end to get a driver in to open it a little, then get another little screwdriver in to lif ti. Worth using goggles too so you keep both eyes intact
posted on 3/4/11 at 07:13 PM Reply With Quote
There isn't always a groove to be able to get behind the circlips out on a lot of items , try using a small pick type tool to get behind it . I had a Fiat Regatta wheel bearing with a similar problem that I wasn't able to get the circlip out from the hub , ended up drilling a small hole down the side of the hub to just below the circlip before I could get it out. Some Clio rear hubs are like it as well . Can't see any problem doing the same with a master cylinder as that end isn't under any stress but be careful you don't overdo it and clear out all of the swarfe
ReMan
posted on 3/4/11 at 07:37 PM Reply With Quote
Yes there def no groove to pick at and its a tightun!
Have made a groove with the dremel but still so stiff its barely budging and cant cut deeper in case i hit the piston
But I still have both eyes
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
MikeCapon
posted on 3/4/11 at 07:48 PM Reply With Quote
I've seen a few assemblies like this (not on cars or bikes tho) and the 'solution' was to drill a small hole in from the outside to enable a similar OD'd rod to compress the circlip. Then a pair of appropriately sized screwdrivers to lever out the circlip.
HTH
Mike
ReMan
posted on 3/4/11 at 08:23 PM Reply With Quote
I'm liking the side hole idea.
i'll give it a go tomorrow
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
