trialsman
posted on 10/4/11 at 02:32 PM |
GSXR can 90* turn out
How are you guys, that have a stock GSXR can, turning the exhaust out 90* so it does not hit the tire or rear wing? I have a 90* exhaust elbow on it
now but the 3 pop rivets that I have on it now keep failing after about 300km. Tks Russ
Bigboystoys
posted on 11/4/11 at 07:43 PM |
I work with aircraft and we use rivets called cherry max rivets, these are vibration and heat proof and should solve your problem. They can be put in
with normal rivet pullers if not to big. Made by a company called textron
ReMan
posted on 11/4/11 at 08:01 PM |
I feel better about flying now
www.plusnine.co.uk
